Gearing
Old Jul 8, 2012 | 12:44 PM
  #91
Ed Grizzo's Avatar
I know your supposed to get the tool to help it from spinning and use big socket and do it by hand. That didn't work for me. We did it at my buddys house who is a machinist. He has an old school super huge compressor. We cranked the shit out of the air pressure and it barely turned. Right before we got the play out, we would just tap the trigger until it just moved. In between bumps we kept checking it with inch pound torque wrench. They say if you go over and back it off, it messes it up. Then you would need a new crush washer. At least thats what I did. We didn't go over as long as you go slow. We got it in the perfect range. We also would tap both ends with a little blow before checking each time to make sure bearing was in place. To be honest, I wouldn't have tried it if he wouldn't have helped me.
Old Jul 8, 2012 | 05:40 PM
  #92
jcs07jk's Avatar
Thanks. I just didn't have enough in my guns. Got another idea I'll be trying tomorrow
Old Dec 9, 2012 | 08:25 PM
  #93
XJ Jay's Avatar
Any one know for sure if the carrier shims are between the carrier and the bearings like on old 44s and 30s or if there between the housing and outer race, I know the Rubicon 44 there placed on the outside but am unsure about the non rubi 30/44. Either I order master rebuild kits cause I'll likley destroy the bearings removing them off the carrier or get what I need at half the cost with a pinion rebuild kit.
Old Dec 10, 2012 | 03:50 AM
  #94
OKJK11's Avatar
They are between the race and the housing, I just regeared my rear non-rubi 44 last week.
Old Dec 10, 2012 | 09:46 AM
  #95
XJ Jay's Avatar
Booyah. I assume the same in the front 30. 5.13s here we come.
Old Jan 6, 2013 | 06:54 PM
  #96
XJ Jay's Avatar
Did the rear today Click image for larger version
Old Feb 9, 2013 | 11:36 PM
  #97
troyboy's Avatar
Wow this is an awesome write up.
Thanks for sharing.
Old Feb 10, 2013 | 06:24 AM
  #98
XJ Jay's Avatar
Front 30. The pinion bearing is larger then the pinion gear.
Old Feb 15, 2013 | 10:12 AM
  #99
Rkb7773's Avatar
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=420390"/>
Did you replace the bearings or use install kit and not the master kit?
Old Feb 16, 2013 | 06:05 AM
  #100
XJ Jay's Avatar
I bought Motive master kits from northridge. They all have Temkin USA bearings but i only used new pinion bearings cause i was to lazy to replaced the carrier bearings.
And now the joys of doing your own gear installs, NO warranty
Not sure what or when this happened. Just changing the oil after break in and i guess i really broke it in. I was gonna take it on its first wheeling trip tomorrow but i guess ill take my XJ. Not to sure how much success ill have with warranty.
