Gearing
Old Feb 16, 2013 | 01:21 PM
  #101
Rkb7773's Avatar
Originally Posted by XJ Jay
I bought Motive master kits from northridge. They all have Temkin USA bearings but i only used new pinion bearings cause i was to lazy to replaced the carrier bearings.
And now the joys of doing your own gear installs, NO warranty
Not sure what or when this happened. Just changing the oil after break in and i guess i really broke it in. I was gonna take it on its first wheeling trip tomorrow but i guess ill take my XJ. Not to sure how much success ill have with warranty.
Hate when that happens. I assume that's the front diff? I'm not an expert but I would think if you had carrier preload right, and everything was in spec....you might be looking at manufacturing defect.
Old Feb 16, 2013 | 01:23 PM
  #102
Rkb7773's Avatar
Hate when that happens. I assume that's the front diff? I'm not an expert but I would think if you had carrier preload right, and everything was in spec....you might be looking at a manufacturing defect.
Old Feb 17, 2013 | 05:13 PM
  #103
XJ Jay's Avatar
I kept the front carrier as well as bearings SO i kept the same amount of total shim and just reset back lash. Had to drive the shim stack in with a brass punch and hammer, like every other diff ive set up. In the past year ive probably done 10-12 gear sets, this is the first time ive chipped a tooth. Both gear sets in my XJ lived through Moab. If it is a defect im out of warranty, Yukon only offers warranty for 1 year after purchess, ive sat on the gears for well over a year, no time for the JK, had to prep the XJ for Moab. Ill talk to my supplier and see whats up.
Old Feb 17, 2013 | 06:46 PM
  #104
Rkb7773's Avatar
Yeah that sucks. Hopefully they can help you out, maybe if you show them the pics of your mesh pattern (if theyll even take the time to look) they'll give you a new set or at least a discount.
Old Mar 24, 2013 | 12:36 PM
  #105
JPop's Avatar
Originally Posted by Slightlymodified
FYI
One out of the archives.
Just a note that the formula for appropriate gear ratio is remiss of stating it is for a 1:1 transmission ratio. So for a vehicle with an overdrive gear you would need to divide the result by the overdrive transmission gear ratio.
Old Mar 24, 2013 | 03:11 PM
  #106
ignatius504's Avatar
Jpop empty your inbox please... been dying to ask you a question about my shift schedule.
Sorry to hijack thread...
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
Old Mar 24, 2013 | 03:40 PM
  #107
JPop's Avatar
OK, mail box cleared.
Old Mar 28, 2013 | 09:28 AM
  #108
crusaderJK's Avatar
Tried to figure out what ratio I have on my '11 Sahara.
I did jack-up the left rear wheel only, so the right wheel wasn't spinning.
I've counted almost 37.5 turns of the driveshaft after 20 full rotations of the wheel.
So now I wanna know if I did it right and my gear ratio is 3.73!?
Thanks anybody
Old Mar 28, 2013 | 12:36 PM
  #109
JeepDave90's Avatar
Thanks anybody
Go to jeep.com register with you vin number and it will give you all your info
Old Apr 20, 2013 | 02:33 PM
  #110
Kurtismcm's Avatar
Do you believe I have my rear end torn apart to do my gears and it appears I received the wrong master install kit from JeepAddons! Uggggg. Anyone have the correct master install kit # for a Motive Gear for a 2007 unlimited 4dr dana44 rear?
