Grill Mod
Old Jun 12, 2012 | 02:21 PM
  #1151
ole' man rubi's Avatar
I did the grill mod twice in the past week..................The tape keeps seperating from the zip tie blocks. It sticks to the grill reallly good. Anybody have any suggestions? I thought possibly epoxy the blocks in place!!!
Old Jun 12, 2012 | 02:43 PM
  #1152
Delux2769's Avatar
Yep, scrape off the sticky from the grill. Then epoxy or gorilla glue the squares straight to the grill.
I first gorilla glued my sticky pads to the grill, took forever to scrape that stuff off to glue the squares down.
Been several months now, gorlla glue's held up fine.
Old Jun 12, 2012 | 08:28 PM
  #1153
JK-47Man's Avatar
Finished mine yesterday, used expanded metal primed and painted! I like it!
ID:	328766   Click image for larger version
Old Jun 22, 2012 | 09:22 PM
  #1154
BigDaddyJG's Avatar
This is happening soon.
Old Jun 23, 2012 | 06:20 AM
  #1155
jkfisher84's Avatar
Taking off the 3m tape sucks! I soaked mine in goo gone for a day or two and they floated right off! Everything went fine til I ran out of 5 minute epoxy! Jb weld to the rescue! Anyone know if this has any effect on a trans cooler or on the top mounted winch as far as air restriction or anything?
Old Jun 23, 2012 | 01:36 PM
  #1156
Antisimplistic's Avatar
I used the same technique, but you really only have to let it sit in the goo gone for about 5-10 mins after taking off the adhesive backing. Then it scrapes right off with a razor with almost no effort.
Old Jun 24, 2012 | 06:50 PM
  #1157
cra5h's Avatar
Default Did the same mod but...
The paint I painted the aluminum mesh with cracked off. So I think I will redo it with non-painted mesh this time.
Also, note that I have hit a bird pretty hard and it held up. It's a little loose now but it's still there. haha.
Btw, the bird didn't make it. In case you didn't know.
Old Jun 30, 2012 | 08:15 PM
  #1158
Deputy45's Avatar
Had my grill rapped & painted the mesh to match my Jeep
ID:	335695   Click image for larger version
Old Jul 3, 2012 | 08:25 AM
  #1159
ddubb's Avatar
That looks sick! I keep seening the Rugged Ridge demo JKs with plastic black grills and want to do this to mine too. PM me if you have info on what paint you used
Old Jul 3, 2012 | 05:45 PM
  #1160
MUSkins's Avatar
Default Did Mine Today
Got around to getting mine done today. Have had the Jeep for just a few weeks, so this was the first mod. Really easy to do, cheap, and looks great. Thanks for all the informative posts. The posts really made it easy. All in all, this mod cost me just under $20.00 - by just a few cents. Like many, I used the roll of gutter guard found at your local hardware store. I soaked the zip tie brackets in Goo Gone overnight. The sticky pads peeled right off in the morning. I then mounted the brackets with Gorilla Glue. To remove the posts that hold the grill in place, I used the thing with which you pry cans of paint open. It took less than a minute to remove all six. Definitely recommend this mod.
ID:	336952   Click image for larger version
ID:	336953   Click image for larger version
ID:	336954   Click image for larger version
ID:	336956   Click image for larger version
