Grill Mod
Old Aug 28, 2013 | 11:27 PM
  #1281
ouroborus2012's Avatar
Originally Posted by stagedtrip
Later dropped the mesh went steel and different Color
Sent from my NSA listening device
Yeah, I DEFINITELY want to go with the steel at some point myself. I simply couldn't find any locally. As soon as I come across some steel with a pattern that I want, i'm definitely changing over also!! Looks awesome on yours
Old Sep 1, 2013 | 12:56 PM
  #1282
stagedtrip's Avatar
Originally Posted by jahbone
That's the size of perforation I wish I could find. Mine are too small, and I noticed my temp. gauge rising when I was in Colorado. Do you have a part number?
No, I grabbed it from work 3/8 perforated steel. Rattle canned it. My fan constantly kicks on so I did a PSP hood Louvre yesterday
Old Sep 1, 2013 | 05:26 PM
  #1283
Erok's Avatar
Yeah. I noticed some overheating when I wheeled Colorado last month. Also, when I got back, I pressure washed at the self car wash nearby, and knocked out all but 3 of the mounts. I ripped it out and am done with it for awhile. I might try a more permanent solution that can stand up to multiple power washes.
Old Sep 1, 2013 | 06:04 PM
  #1284
stagedtrip's Avatar
Mine has been in for 7 or 8 months no problems with it not staying in and I've spent some time with the high pressure
Old Sep 1, 2013 | 11:03 PM
  #1285
Erok's Avatar
Could be my climate. All I know Is I prepped the hell out of mine and used strong epoxy.
Old Oct 27, 2013 | 11:16 AM
  #1286
VividFlunky's Avatar
Used 1/4 20 ga aluminum for mine, plasti dipped it black. Pretty sure it did flatten the grill out once I re installed but not very noticeable. Just has to push a bit more to clip it in. Pretty easy install with tin snips and some patience on the zip ties [center=32.748677,-117.152028&zoom=14&markers=32.748677,-117.152028&size=400x300&sensor=true[/IMG]
ID:	508427   Click image for larger version
Old Jan 7, 2014 | 10:55 AM
  #1287
Tx_jrod's Avatar
Completed my version of this mod with the plastic bumper removal mod as well.
Old Oct 2, 2014 | 10:37 AM
  #1288
masrik's Avatar
Default Parts with Pics ..
SO i got everything i needed for this Mod from Home Depot.
Ill document it with pics but here are the parts i got, total $20.
ID:	578250Click image for larger version
ID:	578251Click image for larger version
ID:	578252Click image for larger version
ID:	578253Click image for larger version
Now that i am reading more posts im becoming leary of the plastic, Anyone else have isses with the powerwash knocking them out ?
Old Oct 2, 2014 | 11:09 AM
  #1289
ohio12jk's Avatar
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=578250"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=578251"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=578252"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=578253"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=578254"/>
I tried the gorilla glue on mine and several mounting blocks popped out the first week, tried the locktite epoxy and it lasted 2yrs on my 12' no problems at all even with ice packed on it all winter. Just did my 14' last weekend the same way but this time had to trim 1/16" off each mounting block that went between each opening, they wouldn't fit this time so the new grilles must be slightly closer.
Old Oct 2, 2014 | 05:20 PM
  #1290
double J's Avatar
Default Grill Mod
I used the lock tite epoxy, plastic gutter guard, and square wire tie holders. Removed the double sided tape from the square wire tie holders, and scuffed the holders, and where the are epoxied. I have no problem pressure washing it and it is holding up without problems.
