Grill Mod
Old Aug 19, 2010 | 04:11 PM
  #781
spleify's Avatar
Originally Posted by Pluke the 2
I used the following from McMaster:
http://www.mcmaster.com/#92725t22/=8h3774
Item # 92725T22
Desc: Hexagon-Hole Perforated Sheet .030Thk, 22 GA Steel, 1/4" Dia, 79% Open Area, 36" X 40"
This the above grill, it made 3 full grills. I would prefer Stainless Steel!
htp://www.mcmaster.com/#7582k22/=8h3baw
Item # 7582K22
Desc: UV-Resistant Cable Tie Holder Adhesive Back/Screw Mnt, 4-Way, for.18" Max Tie, Black
The only bad part about the above is that the actual physical size of the adhesive back mounts did fit between the center lines, or webs, so I had to machine them in half.. So if ordering the above cable tie holders, order half the size. PM me and I can find the right size to work.
I also used the following to glue:
Grainger.com
htp://www.grainger.com/Grainger/GORILLA-GLUE-Super-Glue-4GZK6?Pid=search
Grainger Item # 4GZK6
Desc: Super Glue, Bottle, 15g, Coverage 1 Square Inch per Drop, Temp. Range -65 to 220 F, Clamping Time 30 to 60 Sec, Full Cure 24 Hrs, For Instant Bonding With No Clamping, Indoor Use, Use On Wood, Plastic, Glass, Metal, Ceramics, Stone, Brick, Paper, Rubber, Polyurethane Adhesive, Rubber Toughened, Impact Resistant, Anti-Clog Tip
I used this on the back of the Cable Tie Holder Adhesive Back holders..
The paint I used was High Temperature Gloss Black from Home Depot.
Like always, thanks so much Pluke!! You are always a huge help!!
Thanks
Old Aug 19, 2010 | 06:55 PM
  #782
Ride_My_Jeep's Avatar
Check out your Local Leowes Or home Depot
Alfy
Old Aug 19, 2010 | 08:16 PM
  #783
spleify's Avatar
I went to Home Depot and all I could find was some gutter guard. I picked up a few pieces of it. I will see what I can do with it.
Thanks
Old Aug 20, 2010 | 07:36 PM
  #784
If you go in the nuts n bolts, screws, etc section you will also find aluminum rods alongside packaged pieces of stretched sheet metal
this is what I used
http://www.lowes.com/pd_168753-37672...CatalogDisplay
Alfy
Old Aug 20, 2010 | 08:38 PM
  #785
spleify's Avatar
Thanks for the tips Alfy.
The gutter guard worked out really well, it looks awesome. I will get some pics tomorrow in the day light I finished to late tonight to take any good pics.
Old Aug 21, 2010 | 01:18 PM
  #786
Carbonuts's Avatar
I used the gutter guard, and the wire tie blocks.
I peeled the adhesive off the blocks and soaked them in simple green for about 10 min.
I then used the Gorilla glue on the blocks.
Since I used the gutter guard I did not have to tighten down the wireties very tight. So far it has been on a month and no issues.
Old Aug 21, 2010 | 01:24 PM
  #787
Very nice
That black really stands out on that rescue green...
Alfy
Old Aug 21, 2010 | 02:17 PM
  #788
Carbonuts's Avatar
Originally Posted by Ride_My_Jeep
Very nice
Alfy
TY sir, I have tried to keep the black and green the look for the entire Jeep.
Old Aug 21, 2010 | 05:44 PM
  #789
Danny4652's Avatar
I think it looks better than expanded metal! Nice Job!
Old Aug 21, 2010 | 06:40 PM
  #790
Carbonuts's Avatar
Originally Posted by Oglaladiver
Found some of that the other day at Lowes, but it only comes in a 12 x 24 piece, which isnt big enough for the grill. Did you use a couple of pieces or were you able to find a bigger piece??
The stuff I used came in a roll.
Width wise it was about perfect. I just cut 7 lengths of it and then trimmed them at the bottoms so they cleared the grill mounts.
