Grill Mod
Old May 30, 2008 | 08:16 AM
  #311
[N]UGE's Avatar
Originally Posted by rockd
I didn't find any others.... i'm sure they are out there.. taking the adhesive off was a small pita but worth it the gorilla glue holds great.....
I'll have to give it a shot., did you use some paint thinner or goo-gone to take off the adhesive?
Old May 30, 2008 | 12:52 PM
  #312
CyBrChLd's Avatar
Originally Posted by davebloomer
ok, i had em for a day and like 8 of those things came off... no longer have the grill mod.
You need to glue them on the adhesive tape does not hold..
Old May 30, 2008 | 02:18 PM
  #313
jquader's Avatar
Done...
Old May 31, 2008 | 07:53 PM
  #314
dsword's Avatar
Default Done!
I can't believe how easy it is to get the grill off!
Old Jun 2, 2008 | 05:58 AM
  #315
[N]UGE's Avatar
Originally Posted by jquader
Done...
looks cool. where di you get your grill from?
Old Jun 2, 2008 | 06:30 AM
  #316
Okie4WD's Avatar
Get some 5 minute epoxy or come by and get the gorilla glue. Either way will make it permanent.
Old Jun 2, 2008 | 11:12 AM
  #317
revolucion!'s Avatar
yo [N]UDGE! i found a place in toronto that has this material for relatively cheap(cheaper than online anyways). pm me and i'll send u the skinfo! i'm picking up my material this week and should have the 'cheap' mod done by the w/end.
Old Jun 3, 2008 | 01:49 PM
  #318
jquader's Avatar
Lowes. It was in their sheet metal section.
Old Jun 6, 2008 | 05:35 AM
  #319
KMB-JK's Avatar
I did this mod and used the 5 min epoxy, and it held about three weeks. Not to happy about this. I'm going to try the gorilla glue. I want to make sure I do it right this time. are you using the adhesive tape on the back of the tabs and then dampening the area and running a bead of glue around the tab? What is the point of dampening the plastic? I can understand wood, but plastic?
Old Jun 6, 2008 | 09:44 AM
  #320
ehntr's Avatar
I used fairly heavy steel plate diamond mesh for the grill..........applied the gorilla glude directly to the adhesive on the back of the blocks. It's been a month.......and it's solid. I did sand the grill at each point where the blocks are glued with 120 gr paper. You're right....plastic doesn't dampen.....I did not dampen the adhesive either......the adhesive is already damp isn't it?
