Hard Top removal - ALONE!
Old Apr 12, 2011 | 09:16 AM
  #91
shockwaveaz's Avatar
The first time I slid it on very carefully and then after it was centered I nailed a 2x4 on the three sides on the 2x part facing down. Now I just stand in the middle of the table and push up on the top and move it forward and the 2x4s guide it on perfectly and it eventually stops at the backstop. I even marked holes and drilled for the studs on the top to fall into Works great
Old Apr 12, 2011 | 09:19 AM
  #92
db09JKU's Avatar
Awesome!
Old Apr 13, 2011 | 10:30 AM
  #93
magnum306's Avatar
Nice job and write-up. Good to have in case I need to make one.
Old Apr 14, 2011 | 04:51 AM
  #94
slimmick's Avatar
This is a great idea, there hs been several times I needed to wait for help. Awesome I want one
Old Apr 14, 2011 | 05:11 AM
  #95
rtee723's Avatar
I just made mine....put side rails and a backstop....also added 3" locking casters so I can move it in the garage if need be....now just need some nice weather here in jersey to actually use it...
ID:	149900   Click image for larger version
ID:	149901   Click image for larger version
Old Apr 14, 2011 | 11:25 AM
  #96
Airhawksix's Avatar
I built one of these too...Thanks a million to the O.P., I can now take my top off without having to harass one of my friends for help.
Just a side note; if you have a Wild Boar hardtop, it will fit fine on the paltform, but it will fall forward if you do not strap the back portion down. Because we dont have the option of removing the front panel, the Wild Boar top tips forward.
Old Apr 14, 2011 | 11:59 AM
  #97
db09JKU's Avatar
Ohhh, I like the side rails. Will be doing that very soon to mine!
Old Apr 28, 2011 | 11:27 AM
  #98
4fox's Avatar
I whipped one together last night using 2x4s and a 2x6 for the top even added some scrap 2x4 for a lip after the top decoded to widen a bit while sitting on the, um, "rack".
got it on casters too so I can move it in the garage. need to change to all moving casters as its interesting trying to manuever this thing with two fixed casters!
the thing is super easy to use! cost about $25 in supplies (wood, casters, screws) about an hour to put together and maybe 20-30 min to take the top off.
ID:	154993   Click image for larger version
Old May 19, 2011 | 06:46 AM
  #99
db09JKU's Avatar
Was nervous taking it off, but wasn't that hard at all, just took my time, my wife spotted me.
Putting I back on was even easier. Wife wasn't there.
This thin is a great help'
Old Jul 24, 2011 | 07:30 AM
  #100
cybersymes's Avatar
fantastic job sarge...building this beauty soon...
