Hardtop hoist/storage write-up
Originally Posted by BosoxJK
My simple rig. 4 ratchet straps, 2x4, chain and few eye bolts. About 20$ Takes less than 5 minutes with one person. Pictures aren't great but you get the idea. Really sturdy. Does not move hardly any once its secure
Now I don't have to beg my wife to help me!
Thank for this post and all the ideas on this thread, they were a great help.
My solution is similar to BosoxJK...4 rubber coated J-hooks from Lowes and 2 heavy duty ratchet straps. Just run the loose ends of the straps under the top and lift off one side at a time, simple as that. I've been using this setup for over a year now, zero issues whatsoever. The winch style systems on this thread are sweet, just needed something quick, cheap, and easy...It's worked so well, I just put my cable/winch plans on the backburner..
Originally Posted by Johnnyfever
I just completed almost this exact thing for my hardtop. Worked like a charm and all it cost me was the hooks.
It is very simple. Not as elaborate as others on here but just as sturdy and a 1/3 of the cost. And def no need for the wife's bickering help!
I've found myself in the same situation. I have 1 2x joist then the next 5 are all engineered! I was planning on running a 68" piece of superstrut across them all, which should spread the weight out greatly, but I'm curious to see if anyone else has sunk lag screws into these I beams. From what I've read, it is not recommend, yet my garage door brackets are all lagged into something :(
Look on anI joist manufacturers website and they should have some details on how to install 2x web stiffeners, then install a 2x spanning between the two using joist hangers.
Trust me on this one, I am a structural engineer. Do not put a lag bolt through the bottom flange of an I joist.
back to Lowe's! I already have 2x6, bolts and liquid nail, just didn't get the hangers!
So here's what I'm thinking:
Racor Hoist: Amazon.com: Racor PHL-1R Pro HeavyLift 4-by-4-Foot Cable-Lifted Storage Rack: Home Improvement
- Lower mesh platform down on top of the hard top
- Secure the hard top to the mesh platform by running an X pattern with ratchet straps through the windows and back up to the platform
- Hoist the top as high as desired
Then:
- Slide 2 2x4's (with eye holes out on ends) onto mesh platform
- Hang chains to bottom of hard top
- Attach a section of 1 5/8" uni strut to bottom of chains
- Use existing hard top holes and make a "stud" using a spring nut, skinny bolt, and wing nut to secure the hard top down onto the 2 rows of unistrut
OR
- Hang chains from ceiling
See sketchup model for clarification:
Lifting the Hard Top:
Securing top with method 1
Securing top with method 2
I'm getting ready to buy the pieces for this project soon, and I'll post some real pictures and make a write-up.
Then:
OR
