Home Mod Sway bar disconnects
Old Apr 17, 2013 | 06:57 PM
  #91
Hrdtyme's Avatar
Originally Posted by spw4646
Ok, I've only read a few quotes on this last page and got tired of seeing "3/16 read the receipt".. 3/16 is tiny, that's the size of the hole for a hair pin cotter used in the end of the clevis pin. Yes, 7/16 will go through the bracket and end link without drilling anything, however it will be sloppy loose in the holes. I used a half inch pin, drilled the end links and it works good. It's still loose in the axle bracket but not near as bad and I don't hear any noise from it. I can take and post pics if anyone wants to see them.
Ok here it is, take the second hole to the end of the pin and drill it out with i think was a 1/4 in bit if I remember and see if that will work. I got confused with all of the hooplah in this thread. I did drill out the cotter hole to make cotter fit. Sorry for the mix up.
Old Apr 17, 2013 | 06:58 PM
  #92
Hrdtyme's Avatar
Originally Posted by JLsJK
I want to see a pix of how some of you guys are securing it when disconnected.. Please and thanks
I used a Velcro strap to secure it
Old Apr 17, 2013 | 07:00 PM
  #93
Hrdtyme's Avatar
Originally Posted by glock-n-roll
Yep, I read the receipt. My problem is not with the 3/16" linchpin, the 1/2" clevis pin is too large to fit through the sway bar end links. Therefor, when I get the time, I will hog out the end link holes to 1/2". No biggie.
The second hole to the end of pin needs to be drilled to the next size and if I remember its a 1/4 in drill bit
Old Apr 18, 2013 | 03:11 PM
  #94
Tooadvanced's Avatar
I used a 3/16 bit but 1/4 would work as well. I just wanted to minimize material hog out
Old Apr 18, 2013 | 06:02 PM
  #95
JLsJK's Avatar
If I drill the sway bar end to 1/2 inch do the bushings have to be removed? I haven't even taken my rear sways off yet ever, but I'm going to move them to the front and do this mod...
Old Apr 18, 2013 | 06:28 PM
  #96
Nope leave em in bushing
Old Jun 18, 2013 | 01:00 AM
  #97
jeepchief's Avatar
I want to see pix of how some of you guys are securing it when disconnected.. Please and thanks
this is also what I want to see. I've had this set-up for a couple months now and no idea how to secure while disconnected. everyone can "tell" me all day but I need visuals!!!
Old Jun 18, 2013 | 02:55 AM
  #98
kh202's Avatar
Only pic i've got. More convenient than zip ties in my opinion I actually attach both ends of the strap up top vertically, but either way will work. Works well for me. Hope this helps
Old Jun 24, 2013 | 06:22 AM
  #99
c-rad's Avatar
No it doesn't rattle yet and I hope it doesn't break on road. I keep a spare bolt and nut just in case. All is well so far.
CAN I get some measurements to make sure I pick the right size stuff. Thanks this is great!
Old Jun 24, 2013 | 06:24 AM
  #100
Sirtreysif's Avatar
1/2"x2.5" or 1/2"x3" clevis bolts. Also get 4-6 1/2" washers and 2 clevis pins. Bought all mine from Lowes last week for $8
