Home Mod Sway bar disconnects
Oh i gotcha. I already have this setup so i didn't really look into the reciept. I got mine from Lowe's, mines a 2012. Did you try the 1/2" from home depot? I mean mines just a little loose left and right cuz of the hole position for the pin, but its like 1/16" maybe with the washers. The 7/16" clevis is a pretty decent fit for me.
Just tried doing this mod, but as others have said 1/2" is just too big. Pretty sure I don't want to go with 7/16" if it's a little "sloppy" and finding a metric clevis pin here is going to be next to impossible. I'm going to Uwharrie this weekend so I will just unbolt and strap them up, but afterwards I think I will look into hogging out the end link holes.
I thought about drilling the links out to 1/2 but that made me nervous. Just didn't seem right.
I do have a little rattle and its driving me crazy. May have to switch to 1/2 anyways and open up the links.
OK everyone drilling out the link and bracket to 1/2". Wtf. Why not just grind a little off the pin. They are cheep and if u screw up it was a pin. Not the jeep u just messed up. My 2¢ take it for what its worth
How's it screwing up my jeep. If I get tired of pins and want bolts again I go pick up some 1/2 by 2-1/2 grade 8 for $5 bucks and shazam back to normal no harm no.foul. ohh and 1/2 fits just fine through axle side bracket not drilling
I have a 2012 and with the 1/2' (12.7mm) is to big and the 7/16' (11.1125mm) is to small. The link diameter hole on mine is 11.90mm on one driver side and 11.92 on passenger side. A small amount of play wont matter since my bolts are 11.70mm in diameter and never noticed it.
That's what I'll end up doing if I don't find the right hardware this weekend. I was going to drill out the link, but the same thought as you stated above popped into my mind, if i eff those up, I might as well buy quick disconnects.
Ok hold on....everyone is talking about the pin...I assume you mean clevis pin? Not the linch pin? I can't even get the 3/16"x1.5" linch pin in the holes. I'm doing the driver side if that matters or not. What Am i doing wrong. It's too big!!!!
And I bought everything like the OP receipt says to the UPC code even.
HELP!!!!!
HELP!!!!!
HELP!!!!!
HELP!!!!!
