Home Mod Sway bar disconnects
Old Apr 11, 2013 | 12:55 PM
  #61
Tooadvanced's Avatar
Originally Posted by psheffern
Ok hold on....everyone is talking about the pin...I assume you mean clevis pin? Not the linch pin? I can't even get the 3/16"x1.5" linch pin in the holes. I'm doing the driver side if that matters or not. What Am i doing wrong. It's too big!!!!
And I bought everything like the OP receipt says to the UPC code even.
HELP!!!!!
Ohh and after 2010 1/2 linch pin too big and 7/16 to small so I drilled my stock sway bar link to 1/2 and now perfect fit
Old Apr 12, 2013 | 09:35 AM
  #62
psheffern's Avatar
That's what I'm talking about. The linch pin, the one that goes thru the sway bar link, won't fit thru the holes in the sway bar. I'm not talking about the pin going into the tiny holes on the linch pin.
Everyone on my page now
I bought the same one, 3/16 x 1.5 inch pin(or bolt) and it won't fit. Should I go get a smaller diameter one, or will it be too week I wonder.
How did the OP get it to fit. Mines a 2009
Old Apr 12, 2013 | 11:05 AM
  #63
My guess is that he had to mod a little but he made it sound all easy
Old Apr 13, 2013 | 06:38 AM
  #64
Hrdtyme's Avatar
Bevel the end of the pins. This will make it easier. 😄
Old Apr 13, 2013 | 06:39 AM
  #65
Hrdtyme's Avatar
Originally Posted by Hrdtyme
Bevel the end of the pins. This will make it easier. dde04
Bevel the ends of the pins. This will help it fit better.
Old Apr 13, 2013 | 06:44 AM
  #66
Hrdtyme's Avatar
It was easy on my JK. I only drilled the pin hole a lil bigger to make the cotter fit easier. It will help to do this along will beveling the ends of the pin also.
Old Apr 13, 2013 | 06:45 AM
  #67
Hrdtyme's Avatar
Originally Posted by glock-n-roll
Just tried doing this mod, but as others have said 1/2" is just too big. Pretty sure I don't want to go with 7/16" if it's a little "sloppy" and finding a metric clevis pin here is going to be next to impossible. I'm going to Uwharrie this weekend so I will just unbolt and strap them up, but afterwards I think I will look into hogging out the end link holes.
3/16 pin, READ THE RECEIPT
Old Apr 13, 2013 | 06:48 AM
  #68
Hrdtyme's Avatar
Originally Posted by kh202
7/16" is what everyone uses. Haha it's not "a little sloppy" as far as handling goes. There is no way you can feel a differnence unless you lowered your jeep, put low profiles on and are running road courses lol. The only thing is you'll hear it jingle going over bumps, thats all.
If u use 7/16 is IS sloppy because its the wrong size. 3/16 with a bevel on end. 🙀
  #69
Hrdtyme's Avatar
I didn't mean sloppy as in handling, I meant as far as fitment. I'm confused, if everybody is using 7/16" how was the OP able to do this with 1/2"? It looks like others were able to ho 1/2" without issue, so there must be model year differences. Mine is a 2010, btw.
I come from a sports car background, and extra movement in the suspension is not generally a good thing. I prefer my stuff fitting properly.
😳Read the receipt, it says 3/16
Old Apr 13, 2013 | 06:50 AM
  #70
Hrdtyme's Avatar
Oh i gotcha. I already have this setup so i didn't really look into the reciept. I got mine from Lowe's, mines a 2012. Did you try the 1/2" from home depot? I mean mines just a little loose left and right cuz of the hole position for the pin, but its like 1/16" maybe with the washers. The 7/16" clevis is a pretty decent fit for me.
There is a pic from HOME DEPOT and it says 3/16. This is not rocket science, lol
