JK Resources
Old Nov 1, 2007 | 04:11 PM
James76's Avatar
Default JK Resources
~Mods please feel free to sticky~
I have been seeing alot of questions reguarding the electrical wiring systems in our new Jeeps. There are a few dangerous pitfalls in the Jeep that i feel everyone who plans on doing any add on electrical stuff should be aware of.
*DISCLAIMER*
NOTE: The information on this forum is provided to you on an as is basis with no representation or warranty of accuracy whatsoever. It is the sole responsibility of the installer to check and verify any circuit before connecting to it. Only a computer safe logic probe or digital multimeter should be used. Any website hosting this document or associated documents, assumes no liability or responsibility whatsoever pertaining to the accuracy or currency of the information contained within. The installation in each and every case is the sole responsibility of the installer performing the work, and any site hosting said information or any of its members, host providers and or owners/operators assumes no liability or responsibility whatsoever resulting from any type of installation, whether it be performed properly, improperly, or in any other way. The information is supplied is to be used as a guide only.
Ok now the legal jargon is out of the way, here is the remote starter installation guide for the 2007 jeep wrangler. As soon as the 08 is released (im assuming not much will change) i will post it here.
The first thing to take note of about the 07 and up wranglers, is that Chrysler has implemented whats known and Multiplex wiring or MUX. The purpose of this system is to reduce the..exscuse the crudity here, cluster f**k of wiring that is required in a new vehicle. Basically it allows multiple signals to travel to the various componants of the vehicle and the Body Control Module (BCM) and the Engine Control Module (ECM) via shared wires.
For more on MUX systems and its history in the auto industry Click Here
Alot of the systems most of us need for the things we add such as cb's, radios, remote starts and alarms, fog lights and various other devices can safely be added if we remember to tap into the regular 12v portions of the vehicle wiring and NOT the MUX wires.
IF you were to put a straight hot wire or a straight ground to a MUX wire you could most likely fry the attached componants such as the ECM or BCM. I dont have to tell you that these items are VERY exspensive to replace!
Alright HERE is the wiring chart. Let me know if this doesnt work. I can post it as a picture instead.
Below are some documents and notes about the wiring. As soon as i can get a few more scanned i will post the keyed bypass solution and the diagram that shows the resistor values and how to set up the MUX wires for remote start without a bypass. I should mention that none of this will compromise you vehicle security anymore than it already is now. You would either use a self contained bypass module that contains a similar chip to the one found inside the Jeep key, or use a key with wires wound around it under the dash.
Old Nov 5, 2007 | 05:25 PM
mcnaught6's Avatar
this bundle of wires in the passenger footwell (upper right corner) has the wire for the dome light.
the yellow wire with the thin white stripe is the positive wire that controls the dome light. tap into it to add footwell, or other lights, such as a rearview mirror with map lights, that turn on and off and dim with the dome light.
here is a close-up of the wire, in the bundle. i have placed a quick splice connector on it.
Old Sep 11, 2008 | 01:26 PM
JLRLJK's Avatar
Default Wiring
Thanks for wiring diagram, it's help out alot. I could not locate starter wire in the switch, accordance to 2007 form of color and location, violet/green in hte ignition switch does not exist. I did the voltage check on all the wiring in the steering column. I'm a little bit confuse on the difference between the ignition voltage and starter voltage. Pink/white tested 12v @ON and running, blue/red tested the same way. Is there other test I could test for to locate starter wire, from the starter solenoid the is yellow/gray. I pretty sure it change color somewhere in the wire harness, because I could locate yellow/gray in the steering coumn.
Thanks again
Old Sep 11, 2008 | 01:33 PM
James76's Avatar
the starter wire is Multi-Plexed on the same wire as the accessory. Either Violet green or violet brown. On mine it was violet brown. Do not put straight ground to this wire it uses resistors to activate relays via the BCM Either hookup a bypass module that does this for you, or check the12volt.com for resister values.
Old Sep 14, 2008 | 02:04 AM
JMP8562's Avatar
hey thanks for sharing by chance do you know where the connector is for the seat heaters because i want to run a fuse block inside the cab for gps-cb-rader det-fogs-volt,oil temp-pressure guages ect ect that will turn off when the jeep is not on and by all means IM NOT A ELETRICAN ANY HELP WOULD BE GREAT thanks
Old Sep 24, 2008 | 01:51 PM
James76's Avatar
Finally got around to scanning these for ya guys 2007 is identical and 2009 hasnt been released yet id imagine it hasnt changed any.
Keep in mind if you use the diagram above instead of a bypass that does it for you, you still have the transponder to deal with.
Old Oct 4, 2008 | 05:39 PM
bluerubicon08's Avatar
You don't happen to have any other wiring diagrams, do you? I would love to Re-wire my stock stereo w/ sattelite radio so it is direct, enabling me to listen when the Jeep is not running and the keys are out of the ignition.
Old Oct 4, 2008 | 05:44 PM
James76's Avatar
I will see if i can track that down for ya..tho i have had radios hooked up like that before and quickly put them back to accessory. Not a good idea.
Old Oct 4, 2008 | 05:46 PM
James76's Avatar
Off the top of my head i wonder if you put 12 volts to the radio fuse in the fuse box? unhook the side attached to the radio and put another fused 12v line to it
Old Oct 14, 2008 | 02:23 AM
Gavitron's Avatar
I've got a quick question about the wiring/alarm in the '08 JK; is the factory alarm built-in to the ECM, or is there a module somewhere under the dash?
I'd really like to install a simple 12v siren like this:
http://www.surveillance-video.com/sa...hannelid=SHOPC
and have it sound instead of the horn when the factory alarm goes off. (but without replacing the horn, either.)
Has anyone tried this, or at least even seen an alarm module, or a wiring diagram of same?
