Marker light mod
Yes you did it right..make sure all your wires are making a good connection!! I used the snap together adapters(can`t remember what they are called,you put the 2 wires in and mash the top thus a metal "blade" comes down and cuts into the wires making them spliced together) and the one wire didn`t get cut so the light didn`t work.I then just cut and tapped the wires together so I knew they had good connection and they worked!!
Also make sure your bulb is not blown
I just send you a PM
Did mine yesterday. It took longer for me to figure out how to get the grill off then to do the actual procedure. I went ahead and wrapped some black wire loom around any new exposed stuff to keep a factory look since I have a ton of it laying around.
I can't believe that it came from the factory "broken."
What happens to the side marker lights when the 4 way flasher's are flashing.
And, are the stock side marker bulbs rated for blinking, or do you have to buy a blinker rated bulb.
Thanks ahead of time .
I don`t see why it worked on mine and not on yours
