Marker light mod
Old Oct 16, 2012 | 06:25 PM
  #511
Python's Avatar
Veteran: Navy
Default Can we replace the turn signals with LEDs?
Could someone explain how to replace the fender markers with L.E.D. lights and then as discussed wire them up to be running lights and blinkers...
Old Oct 16, 2012 | 06:33 PM
  #512
Livenudes's Avatar
Go here
http://www.********.com/forums/showt...e-wire-install
Old Oct 16, 2012 | 08:06 PM
  #513
WIRubi's Avatar
So this may be a dumb question and I've never heard of this before now. What exactly is the marker light mod. I've tried to read about 6 pages but all I see is people saying it worked/didn't work and how awesome it is. I always like free mods and need to know! Lol
Old Oct 16, 2012 | 08:14 PM
  #514
Cobb_Sahara's Avatar
Mod to make the side markers blink when you put your turn signals on. Read the very first page of the thread.
Old Oct 16, 2012 | 08:18 PM
  #515
WIRubi's Avatar
Ahhh. Somehow I missed that sentence cause I did look at the first page. Looks like I know what I'm doing this weekend
Old Oct 16, 2012 | 08:23 PM
  #516
I plan to do it when I blackout my grill. I keep waiting because I want flat fenders.
Old Oct 16, 2012 | 08:51 PM
  #517
BoneShkr's Avatar
It's a very easy project to tackle in about 20 mins.
and you don't have to be waiting on doing a fender
mod to do it.
Open the hood and remover the front grill.
make all your connections and changes from
inside the engine compartment.
I ran the cut lead by extending it with a
piece of wire and pushed it through the
wire loom. I bridged onto the middle lead
of the front turn signal. Then I taped
everything with friction tape so you can't
even tell anything was changed.
The dealership I bought it from was wondering
why they don't come like that from the factory.
It really makes the Jeeps much safer as the marker
will now "Blink" and folks to your right or left will
know of your intentions when you use them.
during the Daytime the front and side markers
blink in unison. At Night,(with your lights on)
they will blink alternately.
How it works is pretty simple.
Your taking the negative lead off the side marker
and putting it to the hot blinker on the front turn
-signal.
When the lights are off, and you use your turn
-signal the "blinkers" blink together.
When the lights are on, and you use your turn
-signal the power to turn the front marker on
will cause the side marker to have 2 positives,
thus turning the light off. then when the front
light is off, the positive lead becomes a negative
and the side marker will light up.
thus you will have alternating blinkers.
And this is all done with only 1 wire.
The hardest part to doing this mod is cutting the
wire from the side marker.
I did it from inside the
engine compartment because I wasn't sure of myself.
But after having done this, I'm left wondering, (like
most folks) why it wasn't done at the factory.
Now stop procrastinating and get to it.
Old Oct 25, 2012 | 02:45 AM
  #518
19Delta's Avatar
Default added LED turn and marker lights
I did this mod yesterday, while adding a edge fired led strip along gap beside headlights. They are only amber turn signals when parking lights are off, but they are white when parking lights are on, unless you use for turn signal, then they change back to amber.
Notice they alternate differently if parking lights are on our off.
Here is a short low quality video. http://dl.dropbox.com/u/1377518/2012...2006.28.38.mp4
Let me know if I should do a write up. Super easy.
Old Oct 25, 2012 | 04:04 AM
  #519
codys11's Avatar
You should do a write up. That's pretty cool. Also where did you get the led strips?
Old Oct 25, 2012 | 06:01 AM
  #520
RubiWood's Avatar
Never hurts to do a write up. I am curious to to see where the LED lights are located. Can you show any pics of those in the daylight.
