Project cool jeep
Old Jun 24, 2009 | 09:57 AM
  #41
JIMBOX's Avatar
The freedom tops are hollow, but the rest of the hardtop is solid, with no air space to utilize expanding foam
JIMBO
Old Jun 24, 2009 | 10:48 AM
  #42
Ronson's Avatar
The back of top the around the glass has a large space for foam i think this reduced some of the road noise also .
Old Jun 24, 2009 | 07:41 PM
  #43
rubious's Avatar
great write up! i use the soft top all summer, but this is a great idea! might do it for insulation in the winter time
never again will i bitch about how hot it is in ky
Old Jun 24, 2009 | 07:43 PM
  #44
joejeeper's Avatar
Default tops off?
I really like the insulation- but can you drive with the front panels off without the wind jacking-up (messing-up) the insulation/headliner?
Old Jun 24, 2009 | 08:20 PM
  #45
Ronson's Avatar
Yea no problem everything is stuck together tight.
Old Jun 24, 2009 | 10:11 PM
  #46
BiTMAP's Avatar
i have been thinking about this and rhino liner. why not just spray an actual foam insulator into the top, then sand it to shape/smooth, then apply a finish (carpet or something).
or in the case of rhino liner just put a foam spray then sand then liner.
Old Jun 25, 2009 | 07:23 AM
  #47
donnie's Avatar
From: Simi Valley, Ca., Taylorsville, Ut. and places in between
Maybe I missed it, but what kind of coating did you use on the exterior of the roof?
Thanksa.
Old Jun 25, 2009 | 07:57 AM
  #48
BiTMAP's Avatar
Originally Posted by eisenjj
Do so you can report back to us on your results!
Make sure you us a reflective layer for the radiant heat as well.
where would the radiant heat foil need to go? i don't think it would work to have that then spray on foam.
i think the insulation would be enough if i used polyurethane. and I'm not gonna foil the tub if i sprayed it.
Old Jun 25, 2009 | 05:12 PM
  #49
Ronson's Avatar
Thanksa.
I just used hammered silver paint in a buzz can. Krylon ultimate i got it at Lowes said it stuck to plastic .
Old Jun 26, 2009 | 08:53 AM
  #50
donnie's Avatar
FWIW, Personally, Ill try painting the roof first and see how it does then if I want, I can always add the interior.
But then thats just my line of thinking.
I would like to thank the OP for the info.
He's stating what he did and worked for him.
