'11 3.8L in a '07 wrangler
Subscribed! There is a big difference in response and performance between my 2008 and 2010 (both Rubicon) and always has been, the '10 is quicker, runs smoother and has never had the slow stumble of the '08. There may be a big enough difference in what the new vs old ECU are like to warrant the extra pain of setting it up with the '11 wiring and controller. Just something you might look into
My heat shields came with tabs either. I was referring to the ones welded to the tubes:
I was wondering if those tabs are meant to keep the hose clamps in place.
This would somewhat clarify where the heat shields are supposed to sit.
I am pretty sure the tab in the circle has a Gibson logo stamped into it. You may be over thinking this one. Simply place the heat guard on the correct tube and adjust to where it looks like it will block the most heat from hitting something that will melt.
Are you actually going to use the hardware provided by Gibson to bolt the headers to the collectors? Me and many other users have a hard time to keep those thight. It seems like they tend to shake loose. Someone even tried LockTite and a counter nut but they still shook loose. I have the same problem which is somehow funny because next time I have to take off the fenders in oder to retighten the nuts I can rearrange the heat shields.
Usually I am not so OCD with things but both the cracked factory manifolds and the Gibson headers are driving me nuts.
I'm going to try them. I will leave my inner fenders off for a few weeks so I have easy access while I go through the procedure in the provided instructions. We will see how it works.
Is there a simple procedure to remove and reinstall the inner fenders? I thought they are attached with rivets to the outer fenders and therefore couldn't be reused. So far I always took off the entire fenders which wears out the hardware and plastic clips. I have already had to replace a couple of them.
This is the one I have. Looks like they don't carry that particular one any more, but search on "Plastic Riveter" and you'll get a bunch of hits.
amazon.com/gp/product/B003PF7140/ref=wms_ohs_product?ie=UTF8&psc=1
