3.25" lift, 37s and stock flares. Can it be done?
If I go 37s, will probably add a TB brace, and steering brace of some sort. That should be enough for me. I used to beat the shit out of all my unibody jeeps. I'm more of a overlander/mall crawler guy now.
Ade, I did 5:38s last week along with synergy ball joints. Going with the synergy sleeve kit, braces and LCA skids.
Would be great to see some pictures when it's al done.
Looks like you got it covered with what can be done to the stock axles. You may also want to look at the EVO sleeves as they also have seals (felt with oil) on the outside to stop too much crap travelling down the axle shaft, but the plug weld sleeves like Synergy and EVO are the way to go in my opinion, I've seen people have a hell of a time slide hammering the press kit ones in.
I'll get pics posted up either way. I don't mind dropping the extra funds to make the 37s fit. I just don't want it to drive like shit, when the 35s are so popular on the JKUs. The older I get, the less I'm willing to put up with as far as drivability.
That's good to know. I'll check out the EVO as well, since synergy doesn't give a bundle discount. The weld in sleeves are better than the hammer in, IMO. That's probably all I'll do. I'm not going to go alloys for fear of making the R&P the weak link. I'd rather be stuck swapping a shaft than breaking a ring gear.
I do like the look of a JKU on 37s they seem to be the most popular here on the West Coast.
A little update.
Got my lift installed this weekend. 2.5" Teraflex coil/shock kit with .75" spacers.
I had previously measured from the top of the tire to the bottom of the flare:
Front: 4.75" clearance (stock JKUR springs/1.75" BB)
Rear: 6.5" clearance
After lift
Front: 7.25" clearance
Rear: 7.75" clearance
So I netted about 2.50" front/1.25" rear. The lift was used for about 10k miles, so I don't think I have to worry about settling anymore?
Not sure if 37s are going to work.
After lift
