40's on Ultimate 60's
Old Apr 30, 2016 | 02:45 PM
Hollidizzle's Avatar
Default 40's on Ultimate 60's
With the wider track of the UD60's what backspace do I need to run to have no rubbing at full lock? Going with 40x13.50 Nittos. Beadlock wheels 9" wide. Steering is all Synergy with a hydro as well. Flat fenders and adjustable arms.
Anything else I need to be aware of? Wondering how many have run a similar setup. Pic for what she looks like today.
ID:	645557   Click image for larger version
Old Apr 30, 2016 | 02:49 PM
twinz33's Avatar
How much lift? You want at least 4in of lift and minimum of 3.5in of backspace. You might barely touch your frame at full turn. Pic is when I first installed my UD 60s. 40x1350 toyo mt. 17x8.5 trail ready bl with 3.5 backspace. 4.5in of lift an had to trim a small amount of the front pinch seam an barely touched my frame at full turn
Old Apr 30, 2016 | 02:51 PM
6" lift. I'm going with trail readys as well
Jeep looks great dude
Old Apr 30, 2016 | 02:52 PM
twinz33's Avatar
Also with synergy I had to trim a little off the tie rod adjuster end to make the tie rod fit. Can not use the flip drag link as its already a high steer arm and isn't needed
Old Apr 30, 2016 | 02:53 PM
So do I need to get a new Drag or can I use the one I have? Mine was a flip
Old Apr 30, 2016 | 02:55 PM
twinz33's Avatar
you should have better luck than I did not rubbing with that much lift. Still get 3.5 in backspace. You won't be disappointed. I honestly wish these axles were 70in wide instead of 69in
Do you recommend a different tire width? How are you liking the axles? Mine will be here next week.
Old Apr 30, 2016 | 02:56 PM
I haven't ordered my tires yet so I can still change
Old Apr 30, 2016 | 02:57 PM
twinz33's Avatar
I still used mine. It can be turned either way.
Old Apr 30, 2016 | 02:58 PM
twinz33's Avatar
if you want 40s, 13.50 is as skinny as it gets. I think your on the right track, just make sure you have 3.5in of backspace. Axles are great, one of my best choice mods I've made
