5.38 vs 5.13
What information are you looking for that isn't already in this thread? You know that your rpm's and street driveability will be better. You know about the size consideration if you plan on bouncing through the rocks. A few have already indicated that moving from 5.13 to 5.38 was the right decision for them. (and I will x3 them, since I recently did the same swap). So... ?
The calibration with actual tire size, inflation etc makes the actual speed vs RPM a little tricky, I seem to be around 2800-3000 rpm at what my speedo says is 70mph, (depends if there is a hill or incline) in my opionion the superchips calibration of gears/wheels/speedo/shift points was the most effective in helping my JK run better than stock. I also like to run the 91 octane, although the other settings are similar. I see no reason you wouldn't be happy with the 5.38, some people do just fine with a small pinion
I just dont see how the 5.38 can be that much different than the 5.13. 100 rpms more cant be that much noticable.
