aev geo correction bracket question.
If you have any questions about different lifts or what would work better for your type of driving give us a call at 866-601-5340. We carry a lot of different manufacturers and can answer those questions for you ahead of time so you aren't throwing away money on a kit that won't work for how you want to drive.
Good stuff, works well and priced fairly. If you ever want to sell them, it takes a day or two on the forum and you barely lose anything. I'd definitely do those over the Rancho version for the adjustability. I think the Rancho is a better product, but it failed for not being adjustable.
Yes. The Rancho control arm drop brackets have only one hole. Caster angle ends up 3.5–4° @ 4" of lift and more at 2.5 .. 4.5– 5°.
There's no need to have adjustments. Lower lifts can run with higher caster. Higher lifts can not due to excessive pinion angle.
