aev geo correction bracket question.
Old Jan 8, 2015 | 05:49 PM
black_14_jks's Avatar
Originally Posted by Sierra141
Brakets are great since i'm not rockcrawling in a championship with this jeep.
I feel the same way
Originally Posted by Northridge4x4
If you have any questions about different lifts or what would work better for your type of driving give us a call at 866-601-5340. We carry a lot of different manufacturers and can answer those questions for you ahead of time so you aren't throwing away money on a kit that won't work for how you want to drive.
Ok thanks
Old Jan 9, 2015 | 01:47 AM
kjeeper10's Avatar
Vet Army
Originally Posted by Invest2m4
Good stuff, works well and priced fairly. If you ever want to sell them, it takes a day or two on the forum and you barely lose anything. I'd definitely do those over the Rancho version for the adjustability. I think the Rancho is a better product, but it failed for not being adjustable.
AEV Maintains a certain caster spec at 2.5/3.5/4.5. The holes are not straight up-and-down and I've only read a few instances where somebody changed holes using the AEV Brackets. End result either too much or not enough caster angle. I wouldn't really call them adjustable.
Yes. The Rancho control arm drop brackets have only one hole. Caster angle ends up 3.5–4° @ 4" of lift and more at 2.5 .. 4.5– 5°.
There's no need to have adjustments. Lower lifts can run with higher caster. Higher lifts can not due to excessive pinion angle.
Old Jan 10, 2015 | 04:46 AM
Wingsnut72's Avatar
Love my drop brackets. I have a 2.5", so I have them set that way. I only trail ride. Coupled with low tire pressure I can tackle washboard roads like I never could.
