AEV procal module
Old Mar 30, 2009 | 04:02 PM
freshjk's Avatar
he is telling us of his good experience with the product and you guys wanna make fun! Need more people like this!!
Old Mar 30, 2009 | 04:03 PM
JimmyJoe's Avatar
I have the AEV Procal and I think it's great. I went from getting 11MPH with my 35's to 16MPH. I also like that you can program daytime running lights in any configuration you want.
Old Mar 30, 2009 | 05:16 PM
Suffolk JK's Avatar
Originally Posted by tlpru
perhaps you missunderstood...my meaning of shift point...the power band of the engine...
all i can tell you is the jeep does not bog down in first....i have done this several times..(program tires/then return to normal)
i have had 2 people drive it....i dont know what it does to the computer....but it does make a difference..
or
(((go buy your rocks)))
Again, the AEV ProCal does not modify any powerband of your engine to keep it at a ceterain RPM or correct any 1st gear bog down.
It's all in your head, I'm sorry.
Old Mar 30, 2009 | 05:18 PM
mkjeep's Avatar
Damn, I thought my jk was slow.
Old Mar 30, 2009 | 06:00 PM
RA070424's Avatar
Former Member
Originally Posted by bigbluejk
no... but I can also sell you one that gives you the ability to control throttle through a foot pedal. I know it sounds like sci-fi but the future is here! call within the next 20 minutes, cause we can't do this all day, and both can be yours for 19.99. Just pay separate shipping and handling charges.
Do you have Shamwows included in that deal?
Old Mar 30, 2009 | 07:12 PM
Torrin's Avatar
Originally Posted by redrunner
I have not tried this and I have a Pro-Cal. What about this idea, say you have an auto trans and are willing to deal with an incorrect speedometer reading, couldn't you tell the Jeep (via the procal) that you had bigger tires than you do and make it shift later (at a higher RPM) because the PCM calculates a lower speed than actual for a given RPM? Just a thought. This might make the OD more tolerable, but I it certainly would not be a substitute for regearing.
I supposed you COULD do that, but then your speedo would be totally dorked. I suppose I might try it if I was running 3.73's and 35's.
Old Mar 30, 2009 | 07:13 PM
Torrin's Avatar
I have some magic rocks for sale that correct the shift points for a manual transmission. All you have to do is install the rock in the console and your shift points become controllable just by depressing the clutch and moving the shifter. Price is half that of a pro-cal. PM me if you want one.
Ya, I got one of those too, I will sell it for 40% of the price of the Pro-cal!
Old Mar 30, 2009 | 07:17 PM
Torrin's Avatar
While I understand your point, I own a Pro-cal, and they are nice for what they are. I bought mine specifically to correct my speedo and for the fast RPM setting while winching. I would not want a newbie on the board to buy a Pro-cal believe it would correct the power band on their 6 speed.
Sorry OP, we are having some fun at your expense, there is no reason the Pro-cal should/could have the effect on your Jeep. If it happened, I would believe coincidence more than the Pro-cal.
Old Mar 31, 2009 | 09:52 PM
rjhoop's Avatar
maybe because the spedo is finally right it just gets there faster
Old Mar 31, 2009 | 10:13 PM
Mutts08JK's Avatar
if anything you were shifting by speed and not RPM if that is the case then yes it would make a difference due to the speedo being off and lower than the correct reading and If those magic rocks tend to reduce weight in the JK then tell me how I can get some LOL... as to the OP there could tend to be fluxuaction in the differences of correct reading and incorrect reading. but a very miunte one.
