Am I sagging too much?
Old Sep 24, 2014 | 08:02 AM
  #31
Vladimer's Avatar
Originally Posted by AngryRedBird
Ah, and the Body lift comment does make sense.. yet you just mentioned it.. Thought we were focusing on just the coil area.. and true crap coils (not saying zone coils are) but would make sense..
So here is what I'm wondering.. if these are the zone 4'' lift kit.. has Vladimer checked the products on the page to verify that everything within that check list was installed..
Suspension Lift Kits-2008-Jeep-Wrangler JK | Zone Offroad Products
and seeing how this was installed by someone else.. how can one be sure it is the 4'' and not the 3'' instead..
I checked the kit vs what was in the Jeep and also sent all the images to Zone as well. Minus mine being black and not white, all the pieces are still in the Jeep. Well the adj. front track bar was replaced with the JKS one I had on my 2 door. Otherwise the Jeep is
Originally Posted by DunnyBunny
Synergy. Dual rate. Shouldn't sag. Should settle to 4" and you might even like the ride better
Thanks! I'll check it out, so far my Synergy stuff has been top notch.
Old Sep 24, 2014 | 08:40 AM
  #32
Da10A's Avatar
Originally Posted by Tripletsi
My fully loaded JKU sits at 38.5" front and 39" rear with an AEV 2.5" and true 33's (measured from the same point as your pictures). Depending on the height of your Duratrac's I'd defiantly say you've got some sag going on. TeraFlex 1" spacers would be a much cheaper route than the JKS system.
Are your measurements taken with the hard or soft top ???
Old Sep 24, 2014 | 08:53 AM
  #33
JE8154's Avatar
Good pics none the less.. and the only reason I suggested the sway drops.. was that if one added the spacers.. the sway may be off slightly.. the blocks would bring the sway back to a more relative location.. But adding the spacers on these coils.. may just make them bow more.. Yet I see others say sag.. I'f it was sagging.. The coils would sag or droop.. in his image the coils are being forced to bow.. which could indicate weight or otherwise.. which is what we are attempting to determine.. would adding new coils correct this?.. maybe.. But what about adding coil overs.. the shocks within the coils.. that for sure would limit the bowing effect.. But I'm under the assumption that it's just the front that's bowing and not the back.. is this true?
dude, enough with the sway bar drop plates. If you don't know what you're talking about do the guy a favor and keep your theory to yourself.
Old Sep 24, 2014 | 09:07 AM
  #34
AngryRedBird's Avatar
Humm.. well let's see this is a forum.. Let's see what the definition of forum is in the dictionary..
forum
/ˈfɔːrəm/
noun (pl) -rums, -ra (-rə)
1.a meeting or assembly for the open discussion of subjects of public interest
2.a medium for open discussion, such as a magazine
3.a public meeting place for open discussion
So in essence.. my points are valid.. because they are open to discussion.. or is this forum lopsided or one sided..
Old Sep 24, 2014 | 09:20 AM
  #35
JE8154's Avatar
Humm.. well let's see this is a forum.. Let's see what the definition of forum is in the dictionary.. forum /ˈfɔːrəm/ noun (pl) -rums, -ra (-rə) 1.a meeting or assembly for the open discussion of subjects of public interest 2.a medium for open discussion, such as a magazine 3.a public meeting place for open discussion So in essence.. my points are valid.. because they are open to discussion.. or is this forum lopsided or one sided..
except your suggestions make no sense and add nothing to the discussion. The guy has cheap coils that are sitting well below advertised height. Your suggesting the sway bar is pulling him down and that he should get coil overs to correct the bow. With every post you make it becomes more and more apparent you know nothing about what you're talking about. So stop posting and just read.
Old Sep 24, 2014 | 09:26 AM
  #36
Actually, this is up to Vladimer to decide if any of my comments are valid.. and if he suggests that this may not work for his application, then I'll discontinue posting within his thread.. but really you missed my point.. added the sway drops & added spacers will throw the geometry off.. unless you prefer to have the sway bar point down towards the ground at about 10° or so..
Oh and.. if this isn't an issue.. then maybe one needs to search the net, key words: "Sway Bar Drop/Relocation Brackets" plenty of results.. but most are rather flimsy looking..
So I guess I'll take your advice.. and discontinue my sway drop support.. can't wait to use these on the jeep.. Seems it's peaked more than a few interested persons, so much so several have asked for a set.. we'll just have to wait and see.
Old Sep 24, 2014 | 09:32 AM
  #37
Tripletsi's Avatar
Hardtop.
Old Sep 24, 2014 | 09:34 AM
  #38
JE8154's Avatar
take one look at the picture he provided. His sway bar isn't pointed down. Even if it were pointed down a 10 degrees it wouldn't pull his coils down and cause them to sag.
Old Sep 24, 2014 | 10:07 AM
  #39
14Sport's Avatar
On a side note, Vlad, is that front skid bolted directly to the factory crash bar and if so, who makes it?
Old Sep 24, 2014 | 10:11 AM
  #40
DunnyBunny's Avatar
JK-Forum Ambassador
True and I would suggest adjustable links over any sway bar brackets. Have added benefit of disconnects that's way.
Synergy makes great stuff. Didn't read the whole post but if it's a 2 door you will want the 3" springs. They are 4" for the 2 doors.
