Am I sagging too much?
#41
I agree . I would not use sb drop plates on the front swaybar. on the rear maybe in certain situations but not on the front.
#42
I appreciate everyone elses suggestions. I don't believe the sway bar would be the culprit as it is pretty level and I can stuff and drop all the tires without any binding or issues. If anything I would think the CA's would be to blame as I only have front lowers. But I really don't think they are that far forward or back to cause that much deflection in the coil
Looks like the Synergy 4.5" dual rate coils will be a good place to start and see what it does from there. If I still get the coils bowing then it would probably be due to some other issue in the suspension. Would that be a valid assumption and action?
#43
Not all Synergy coils are progressive. Iirc someone recently upgraded to 4" and the coils were linear. I could be wrong.
The RK triple rates are fantastic coils. Check out the 3.5's
2007 Rubicon /2 door/6 speed
#44
The 2" and below Are linear. Don't you have a set of 3.5" RK coming off soon. Lol.
#45
#46
I have a 4 door and heavy front/rear full width bumpers + some armour, so figured the 4.5's would sink just a little to 4"... would it be better to go with the 3.5?s Would rather not be just at the same lift as I am presently or else it would defeat some of the reason in replacing them
#47
The higher coils are linear
Part #APPROXIMATE LIFT HEIGHT
(2 DR JK)APPROXIMATE LIFT HEIGHT
(4 DR JK)SPRING TYPEFREE LENGTH
(INCHES)BLOCK HEIGHT
(INCHES)
8063-102.0"1.0"PROGRESSIVE20.750"8.560"
8063-203.0"2.0"PROGRESSIVE20.750"7.440"
8063-304.0"3.0"PROGRESSIVE21.375"7.750"
8063-455.5"4.5"LINEAR21.375"7.750"
8063-607.0"6.0"LINEAR22.000"9.300"
Note: Spring free length increases with lift height for compatibility with longer extended length shocks
(INCHES)
#48
Well that is a bummer, 8064-45 was the part number I was looking at. So Now I am a bit stuck, should I stick with the 4.5 linear synergy's? I can pick them up in about an hour, or go with something else and wait for shipping. Are there dual rate/progressive 4" springs around the same cost?
#49
Reading up on the Linear vs Progressive vs rest debate and it looks like Linear would be preferably avoided. Although a lot of the dual/triple rate springs out there seem to be 3.5 instead of 4" or then bounce up to 5.5"
#50
(INCHES)
(INCHES)
