Aussie Locker guys
Old Apr 28, 2009 | 01:50 PM
mkjeep's Avatar
Default Aussie Locker guys
Hey, the shop is trying to tell me that a Lockright locker in the frt is gonna make noise all the time. Does your Aussies make noise? Sounds like a dry bearing/ chain rattling noise after 30mph in 2wd. The output pinion flange has about an inch of play, or 10-15 degrees of rotation before it stops, does your Aussie do this? I think I'm being fed a line of crap. They said they called Richmond and it was within tolerence. Please give some feed back on your Aussies, I don't think Lockright is right for the JK.
Old Apr 28, 2009 | 01:53 PM
bigbluejk's Avatar
I hated mine. Sold it for $100. Now I am saving for ARB's.
Old Apr 28, 2009 | 01:56 PM
mkjeep's Avatar
Bigblue, did yous make noise all the time or was it just the handling.
Old Apr 28, 2009 | 02:10 PM
bigbluejk's Avatar
Drove like it was engaged all the time, and clicked and clanked more than I wanted.
The Aussie and the lockright are almost exactly the same in design. They are telling you that the Aussie wouldn't make noise but the Lockright would? Both will click and clank when you turn sharply.
Old Apr 28, 2009 | 02:11 PM
mkjeep's Avatar
It clanks when I'm drivin straight
Old Apr 28, 2009 | 02:13 PM
mkjeep's Avatar
I wouldn't mind the clank when turning sharply, it's making noise when I go straight.
Old Apr 28, 2009 | 02:16 PM
bigbluejk's Avatar
here is a lockright:
Here is an aussie:
Pretty much the same thing. I don't see how one could be better than the other?
Old Apr 28, 2009 | 03:06 PM
lnufnu's Avatar
Just to be clear, the aussie, and other lunch box style lockers should NOT make any noise in 2 wheel drive.
In 4 wd, when traveling straight, there should be no noise, when in a turn and one wheel needs to turn faster than the other, you will here a distinct ratcheting noise, in the aussie at least its not that loud and barely even audible inside the jeep.
Lnufnu
Houston, TX
Old Apr 28, 2009 | 04:26 PM
mkjeep's Avatar
Thanks everyone, I'm distraught at this point.
Old Apr 28, 2009 | 05:22 PM
chuck45's Avatar
I hope you paid for it with a credit card. If so dispute the charge. I'd can it if I were you and put the bucks towards an ARB.
