Bad u joint?
Old Sep 18, 2011 | 06:18 AM
ms5490renegade's Avatar
Default Bad u joint?
I have a 3.5 inch lift and 35's. Haven't done more than 2k miles all highway with the man tires. I'm now getting a metallic sound and vibration coming off the front end somewhere. Could this be a bad u joint or worse?
It's a 2010 2 door BTW
sent from a super duper awesome EVO 3D
Old Sep 18, 2011 | 06:22 AM
Cpt. Flapjack's Avatar
Could be u-joints, but I would look at your driveshaft also.
Old Sep 18, 2011 | 07:16 AM
Bull's Avatar
May be more to it then the U joint if your are getting sqeeling and vibration while in 2wd. May be a little aggressive on your driveshaft angles in the front since u joint lasted 2000 miles.
lots of options. What are you running now? There are off set u joints that will allow a little more driveshaft angle without binding which may be the less $$ approach to start trouble shooting if you're not running them already.
Old Sep 18, 2011 | 09:20 AM
Well I had the cv replaced and the shaft remanufactured about 6 months ago. It shouldn't be bad already. What about wheel bearings?
Old Sep 18, 2011 | 09:22 AM
Rubicon10's Avatar
Its hard telling with a little info.
Old Sep 18, 2011 | 12:22 PM
I honestly don't have much to give. It's obviously rotational and happens after a right turn the most
Old Sep 18, 2011 | 12:35 PM
What the hell could have caused this?
Old Sep 18, 2011 | 12:44 PM
nthinuf's Avatar
Your 3.5" lift
Old Sep 18, 2011 | 02:24 PM
Originally Posted by nthinuf
Your 3.5" lift
I have only done highway driving and that's only been on for 3 months. How could the lift tear something that is a straight line
Old Sep 18, 2011 | 02:40 PM
nthinuf's Avatar
That's your front driveshaft? You have an automatic? You have a 3.5" lift? That little avatar pic is you on the freeway? Or it's you offroad flexing a bit?
It is far from uncommon for lifted auto's to have front driveshaft contact on the corner of the tranny pan.
