Bare minimum needed for 37's?
Old Jan 18, 2013 | 07:41 AM
tucsonprerunner's Avatar
Originally Posted by 1LuckyJK
this one is before flats and it would rub, after i installed the flats no problem.
Attachment 410750Attachment 410751
What brand are ur flat fenders?
Old Jan 18, 2013 | 07:46 AM
1LuckyJK's Avatar
Poison spyder
Old Jan 18, 2013 | 07:51 AM
JK yeti's Avatar
Can i go out with resleeving and guessets though? I dont want to spend this money since im upgrading my front to a d44 hopefully this summer..
Old Jan 18, 2013 | 07:56 AM
Ryan0260's Avatar
Originally Posted by LikeMike850
I'll get the exact sizing today and report back.
If i get a 1 inch body lift do you think i will still have to trim my fenders? I really dont want to cut them because when i move down to 35's it will look bad..
Honestly I would just skip the 37's, and wait for the 35's. Too much effort for a temporary solution. Driveability will suck with that gearing as well. 35's more manageable, but you will want a tuner or procal to calibrate the tire size. And definitely pick up the gussets either way. You can actually bend your "c" hitting a pothole on the street
Old Jan 18, 2013 | 08:05 AM
JK yeti's Avatar
Man this is getting dificult.. If i get the guessest can i run the 37's for a couple months without wheeling and be safe? Meaning no damage?
Old Jan 18, 2013 | 08:36 AM
JK yeti's Avatar
Bare minimum. I will ned to cut my pinch seems? Everything else is not needed Just recomended?
Old Jan 18, 2013 | 11:58 AM
Ryan0260's Avatar
All the gussets do is strengthen the front axle. It does nothing to help with clearance or driveability. I would get them even if you only go with 35's. They are inexpensive
Old Jan 18, 2013 | 12:07 PM
otservice's Avatar
Put the tires on and check clearance of everything. Cut areas that may hit and run the 37s.
Everything else is recommended as running 37s does increase wear and tear on the Jeep. These things aren't built to be beat on with big rims/tires etc, but they will last just fine. I know enough guys running 37s on stock JK drivetrains 3.21+ gears that I wouldn't worry about it. The only guys I know who have ever broken anything were beating on the Jeep so hard you'd think it was going to explode.
Old Jan 18, 2013 | 05:22 PM
JK yeti's Avatar
That's the plan! Picking them up tomorrow morning going to make a couple cuts, then getting them mounted at discount tire! I'm so excited! I also don't plan on cutting the fenders for now!
Old Jan 18, 2013 | 05:40 PM
JK yeti's Avatar
Got another question! Am I going to have to do anything to the back bumper?
