Bead locks
Old Jan 2, 2016 | 06:19 PM
  #101
Wrangeler X's Avatar
My discount tire shop balances my 37"MTR on steel wheels.
No problem. These are heavier than the beadlocks I have coming
They said they will balance those also
Northridge 4x4
  #102
sea bass's Avatar
I would get them balanced. Mine had the 50mph shimmy until getting them balanced.
Yes - road force applies a drum to the wheel to simulate the weight of your vehicle I guess? I was surprised it didn't spin very fast. 3 wheels had almost zero weight - 2 took quite a bit.
That's ridiculous to say they don't need balancing because they're heavy bead locks. Find a new shop!
Old Jan 2, 2016 | 08:04 PM
  #103
mhockey9090's Avatar
Vet Army
Originally Posted by nhk19
Thanks! Maybe! Still thinking.... from reading all these posts....what's going to wear prematurely because they aren't balanced properly? Bearings? Ball joints? Is there no vibration now cause everything is brand new and tight? Shop says their balancing machine cannot balance a tire/wheel combo this heavy. Says they never balance a Beadlock wheel / tire over 35". And...they put on a lot of them. Hmmmmm?
Like said above. If they haven't touched them before, I would get a second opinion.
Northridge 4x4
Some places will probable just balance as they didn't physically put them together, but in my area they still won't touch them regardless.
Old Jan 2, 2016 | 08:15 PM
  #104
nhk19's Avatar
Thanks everyone! Definitely going to get a 2nd opinion.
Old Jan 4, 2016 | 04:31 PM
  #105
Vet Army
Does it need to face this way or towards the lip of the rim? Not sure as i've never dealt with these tpms and unsure if they will not have correct readings due to direction.
Old Jan 4, 2016 | 04:40 PM
  #106
Invest2m4's Avatar
I'd NEVER let a tire shop assemble beadlocks. If you can't assemble yourself, you shouldn't be running them. I've seen first hand what happens when you let local tire shops assemble them. Even most off road shops. Some kid ends up doing the torque wrench (if you're lucky, usually they just jam them down with an air ratchet).
Old Jan 4, 2016 | 04:46 PM
  #107
LVJK's Avatar
Pretty sure they are non directional.
O||||||O
Old Jan 4, 2016 | 05:01 PM
  #108
Vet Army
O||||||O
I kind of thought the same, but I didn't want to get everything together to be told they are directional haha. I may go ahead and turn them so they are more towards that lip and should have more protection when I air down.
Old Jan 4, 2016 | 05:25 PM
  #109
LVJK's Avatar
Mine are mounted inside the wheel fastened to the inner beadlock band. The valve stem is facing in direction of wheel rotation or reverse rotation. Either way, they transmit once they sense rotation. This is how Hutchinson mounts the TPMS if you want to run them. Click image for larger version
Old Jan 4, 2016 | 05:29 PM
  #110
Vet Army
Mine are mounted inside the wheel fastened to the inner beadlock band. The valve stem is facing in direction of wheel rotation or reverse rotation. Either way, they transmit once they sense rotation. This is how Hutchinson mounts the TPMS if you want to run them. Attachment 633720 O||||||O
Yeah I guess it doesn't matter then as other ones Ive seen towards the sides of the rims. Good stuff, thanks man
