Best way to delete holes from hood bumpers and rear tire carrier??
Old 10-24-2017, 07:02 PM
AXIS's Avatar
Default Best way to delete holes from hood bumpers and rear tire carrier??
I want to get rid of the giant bumpers on the hood for the windsheild tie down but I dont know what the good options are. I also have had my rear tire carrier holes (just the big ones outside of the main bolt pattern area) just taped over with black electrical tape for a couple of years now and thought maybe its time to do something a bit cleaner. Any suggestions?
Old 10-24-2017, 08:08 PM
cedarraider's Avatar
I used elevator bolts (1 1/4 inch I think) on the hood. Had to use washers (bigger than the bolt to get over the square part of the bolt) to space it out under the hood. I bed lined them and then put black rtv on the bottom of the bolt head and when it was dry bolted it on. Click image for larger version
Old 10-25-2017, 02:09 AM
bilash31's Avatar
There was a product designed specifically for that. It was called something like UFO hood something or other. Google that. If they still exist.
Old 10-25-2017, 02:50 AM
karls10jk's Avatar
Vector off-road sells the UFO's and there's a guy on eBay if you search for JKPlugs he should pull up. He's at $8 to ship you everything for the tailgate though the Vector looks more modern than a plastic plug.....though the plastic plug is very discrete when installed.
Old 10-25-2017, 08:18 AM
uf126's Avatar
X2 on the Vector UFO's. They run sales for all major holidays. I'm sure you can search here to see when they do it. I'd assume a Thanksgiving/Black Friday sale is around the corner.
Once you get them, say adios to your hood nipples!
Old 10-25-2017, 10:59 AM
Erok's Avatar
I bought some plastic plugs for a few cents, I think from Lowe's. Just pop out the bumpers that are in there now, and take one with you to the hardware store. I spent at most, a dollar.
If you can't find them in your hardware store, there's these for $13 on eBay.
Old 10-27-2017, 09:53 PM
TheTerminator's Avatar
I ripped off both of the "giant bumpers" on the hood while off roading, so now just have open holes. I see no problem with that, maybe they even help with cooling a bit.
Old 10-28-2017, 04:54 AM
zstairlessone's Avatar
???? How😱?? Any pics or video? There has to be a really good story behind ripping them off wheeling 👍🏻.
Quick Reply: Best way to delete holes from hood bumpers and rear tire carrier??
