Bestop trektop question
Old Oct 11, 2014 | 08:12 PM
xrayjeeper83's Avatar
Default Bestop trektop question
Recently installed a trektop and when I removed the rear windows the very back of the top flapped around. Yes I had the plastic hooks in the right place, but they just fall out when I hit the interstate. Did I do something wrong or a normal problem?
Old Oct 11, 2014 | 09:12 PM
Jersey_Devil's Avatar
The small ones in the back? They go around the small ones on rear window? Pics would help.... Sometimes those small rear ones come up everytime you drive if it's not on just right. It's more of an annoyance than a problem if they come up, it's all about getting the rear window perfectly centered.
sent from my obama monitoring device
Old Oct 12, 2014 | 04:42 AM
blue project's Avatar
Mine flaps like crazy at speeds over 40. If your referring to the clips by the sound bar, they always come lose. If your referring to the ones by the tail gate, pull them tight and take the extra strap part from pulling it tight and tie it around the the strap so they can't loosen up. You will still have flaping issues and learn to ignore it.
Old Oct 12, 2014 | 08:22 AM
Mine didn't flap at all till I installed a 50" light bar and spyder shade. I corrected that but using carpet padding in the door surrounds :-)
Old Oct 12, 2014 | 09:21 AM
I'm talking about the ones at the top. The ones that go into the silver metal bar.
OK so I'm gathering its normal and not to worry about it
Old Oct 15, 2014 | 10:31 AM
OK so today is a beautiful day here so I took the windows off and went bikini mode. As soon as I hit the interstate that clips cane out and the top started flopping and blocked my rear view mirror. Obviously thats a big problem. Guess I need to call bestop
Old Oct 15, 2014 | 12:51 PM
3rd Jeep's Avatar
Mine flapped around at hwy speed too. I found a suggestion on one of the forums. Pull out the flat aluminum rear bar and replace it with a 5' x 1" steel pipe with two screw on end caps. Worked like a charm! No more flapping at all. Try it out!!!
Old Oct 15, 2014 | 02:30 PM
TRAUMAhead's Avatar
Seems to be a problem with the 2 doors only. With the 4 door the metal bar rests on the roll cage cross bar so it's solid without the windows. There's a thread floating around on the steel pipe fix that 3rd Jeep mentioned.
Old Oct 15, 2014 | 04:11 PM
I have a 4 door. Mine doesnt just flap, it falls down. If someone was sitting in the back it would hit them in the face.
I'll try the steel bar.
Old Oct 15, 2014 | 10:19 PM
TRAUMAhead's Avatar
Any pics? I've done 4-5 hour trips one way in Bikini mode and no doors. Never had a problem with it unhooking.
