Bump Stop question
Bump Stop question
I recently put 37s on my 2014 JKUR. Now, one issue I'm having is the tire is rubbing the body of the Jeep when the tire is full stuffed. It is just barely rubbing, but it is making contact with the metal. I think I could trim a little metal but I'm not quite ready to do that yet. So, I'm thinking I need to go a little bigger on the bump stops. I have the Mopar Stage 3 lift on it so it already has aftermarket rear bump stops I just need a little bit more back there. Is there some way I can extend or add a spacer of some sort to give me just a bit more, I'm thinking 1/2 inch to 1 inch would do it? What suggestions do you have or what product would you recommend?
Metal cloak have bump stops that stack so you can fine tune the adjustment. Depending on what your rear axles side has now you can always buy some thick aluminum plate and install on the perch.
I ponied up for the adjustable MC rear bumps. Really hated to spend that much for bumps, but I knew down the road I have a couple adjustments to make and having bumps I could tweak easily in 1" increments made sense. As Dirtman suggested, maybe add some flat stock to the perch if you need just a little bit. If you need a full inch, maybe a hockey puck could work.
I presume the trimming your trying to avoid is seam at the top of the rear wheel well.
i have a question about bump stops.
my JK have 4'' lift and 35'' tires without bump stop! but i dont know if come the time to install bumps!
before, i removed my discos and in full flex my tire hits the fender.
now, i sold my quick discos and i installed JKS FLEX CONNECT SWAY KIT. Jeep JK Flex Connect Disconnecting Link System
i dont remove anymore my new JKS FLEX discos but my flex (with the softer spring,blue) i believe is 20%-25% smaller than the full free sway bar.
the good new is dont rubbing and the bad i lost little more flex..
my questions are:
1. need bump stops when i dont rubbing my fenders?
2. if i remove the JKS FLEX for bigger flex..i will need bump stops...ok, i know it!
but if install bumps perhaps lost again my full flex?? ..So it will not make sense to do it!
can you tell me please your opinion?
my questions are:
my questions are:
my questions are:
If you are completely happy running the Flex Connects, that eliminates the issue of stuffing your tire (but is obviously limiting flex)....just make sure you're not abusing your shocks at that point.
you are right and i was looking at sites for bump stops.
today i checked my JK and i saw on the rear axle,on the right point who i ll install the bump stop, a strong hit.
is this from a full flex? but i can't see anywhere where has bump it
with FLEX connect in full flex the compressing of the rear shock is this:
That particular spot looks to line up with the bolt that runs through the other side of your track bar. I added bumpstops to mine but also notched that portion of the pad- not the correct way to fix the issue, but a fox nonetheless.
Speaking of which......4" and no raised mount in the rear? There's potential to tear that stock bracket from the axle. You will gain a better roll center and notice better cornering characteristics by raising it.
you are right and i was looking at sites for bump stops. today i checked my JK and i saw on the rear axle,on the right point who i ll install the bump stop, a strong hit. is this from a full flex? but i can't see anywhere where has bump it <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=674227"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=674228"/> with FLEX connect in full flex the compressing of the rear shock is this: <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=674229"/>
