Disco question
Old 09-30-2009, 04:09 PM
mailman1119's Avatar
Default Disco question
so i recently removed my 2" OME lift kit due to DW issues and i left my JKS disconnects on there. I didn't even think about it until i looked at the sway bar just now. Is there a problem with running a disco meant for a 2-6" lift on a stock set up? the angle of the sway bar is probable 45 degrees now...thanks guys
Old 09-30-2009, 04:39 PM
marcoseddi's Avatar
Default ome
so the ome set up was so bad you couldnt leave it on
Old 09-30-2009, 05:10 PM
ibjeepr's Avatar
Make sure you have your JKS discos adjusted to the shortest length possible and it probably won't be much of an issue. I assume you'll be getting another lift anyway. You may as well keep them. Your sway bar should be completely horizontal but a little angle doesn't seem to do much. I didn't really notice much difference with the sway bar completely disconnected just running around town.
I'm surprised you had that much issue with an OME kit. That's the lift i wanted but it was too expensive and the deal on my RC was too good to pass up.
Old 09-30-2009, 06:08 PM
yup, unfortunately that was the case. i got a death wobble and tried for months to try to make it go away but nothing did the trick. if removing the lift fixes the issues, i gotta think its lift related. we'll see. i've heard nothing but good things about OME which is why i went with it...
Old 09-30-2009, 06:10 PM
yeah i'll eventually get another lift in there i think. so i'll keep the discos, just wasnt sure if i needed to go back to the stock links in the meantime is all. i hated driving without the sway bar on! it rolled everywhere!
Quick Reply: Disco question
