Dodge charger springs.
My buddy lowered his charger, so he's got his stock springs laying around. I grabbed a rear one today and matched it up to my stock fronts. They are a few inches longer than my spring and 2inch spacer while its uncompressed. So I would imagine that when compressed they will still be 2.5-3 inches longer than stock front springs. They look as if they will fit in the stock location and they are thicker and beefier than the JKs. Which makes sense because they're mopar springs, and they're made to handle a car with a V8. I'm going to try to swap them in next week. If all goes well I might be able to ditch my 2inch pucks for 3 inch coils for free.
So does anybody think there will be any issues? Has anyone done this before?
I have an adjustable RK front track bar, terraflex extended disco, good up to 4inches, skyjacker shocks, good up to a 3inch lift, extended bump stops, and I will be purchasing adjustable LCAs in a week or two. So the only thing I'd need is brake lines, and eventually a flipped drag/raised track mount. But I could survive without one.
I was more asking if the whole rear charger spring to front jeep spring could cause issues.
If I am reading it right, and by the looks of his signature, He already has 2" lift with Nitro shocks, It sounds like he is trying to ditch the stock springs and Pucks, for springs only. Swap them out and let us know how the ride is!
Well as I said I already have 2inch pucks, so I have most of the other stuff needed.
My opinion....the spring rates are going to be vastly different. Even if they don't sag, I think the ride will not be good.
I look forward to your results and admire your willingness to experiment.
That being said....when doing a mild lift....springs are typically one of the less expensive items to upgrade. Shocks and control arms is where the $$$ are spent.
Worst case they don't fit and I'm right back where I am now. After I get LCAs I was planning on getting RK 2.5 coils anyway. Best case I saved myself a few hundred bucks and got free coils.
