Does a locker improve axle strength?
Old Jan 14, 2009 | 07:00 AM
ucfavenger's Avatar
Default Does a locker improve axle strength?
I am planning on "building" my front D30 to handle larger tires (37's-38's): chromo axle shafts, c-pillar gussets, and 5.13 gearing.
but from my research it seems that adding a locker would increase my spline count...
1. does a locker add any strength to my axle? if so, please explain.
2. will my chromo shafts be incompatible with a locker if i were to add the locker AFTER the chromo shafts. ie: different spline count axle shafts needed.
3. After "building" my D30 as explained above and also running 1310 driveshafts, i understand that my weakest point will now be my spider gears. what is that exactly and does a locker and/or regearing help?
Well, thanks in advance for any support or assistance. i really appreciate the members and info on this forum....
Todd
Old Jan 14, 2009 | 07:12 AM
Northridge4x4's Avatar
Sponsoring Vendor
Sure it does,
For instance ARB Spider gears are made out of 300M which = very stong stuff
Factory spider gears are not the strongest thing in the world.
David
Old Jan 14, 2009 | 07:15 AM
MJS_Jeep_888's Avatar
Originally Posted by Northridge4x4
Sure it does,
David
Have to agree with that second statement. When I had my regear done, the stock spider gears that came out of my JK (with less than 19K miles on them) were already showing severe wear... probably wouldn't have lasted until 30K miles, but it's possible I got a batch set from the factory?
SASQUATCH's Avatar
Todd
Lockers definitley do not add strength per say to the axle, but to the internals it can as stated above. I'm sure some of these guys running the Aussie locker, etc will pipe in and help you out on that D30 and what lockers you could use to match your cmoly shafts.
The following will enlighten you a little on differentials in general along with spider-gears..
http://auto.howstuffworks.com/differential2.htm
Sipder-gears
Old Jan 14, 2009 | 07:20 AM
britjk's Avatar
It will add strength to your gears - stronger shafts will add strength to your shafts and gussets will add strength to your " axle". No - the Locker in itself will not strengthen your "axle".
Old Jan 14, 2009 | 07:30 AM
ucfavenger's Avatar
really great info. Sasquach: that diagram is perfect!!
let me absorb all this info and i am sure i will have more questions.
thanks again!!!!
Old Jan 14, 2009 | 07:37 AM
ucfavenger's Avatar
ok, so a locker replaces the spider gears? am i understanding this correctly?
Old Jan 14, 2009 | 08:03 AM
Sponsoring Vendor
Yes it does. The locker replaces the entire carrier.
David
Old Jan 14, 2009 | 08:14 AM
ucfavenger's Avatar
that makes so much more sense now...
thanks.
Old Jan 14, 2009 | 08:31 AM
britjk's Avatar
David
David - your attention to detail and all of your Forum input gets you great kudos from me. Keep up the good work.
