Drive Shaft Snapped on Freeway
Old Oct 26, 2012 | 08:38 AM
ttfhell's Avatar
Originally Posted by drumnatural
Stock front pinion angle is NOT good for an aftermarket driveshaft which is double cardan design. And it looks like that exhaust pipe has some dents as well.
I'll post the printout tonight when I get home as it shows both mine and the stock settings. Thanks
Old Oct 26, 2012 | 08:55 AM
wayoflife's Avatar
JK-Forum Founder
Originally Posted by ttfhell
Thanks for the reply! Vibes literally just started right before the break.
if that's the case, your vibes were being caused by the shaft failing. if i could guess, the shaft had some kind of crack, stress fracture or poor weld that finally started to give out. total distruction was inevitable. hate to say it but, looks like you just got a bad shaft.
Old Oct 26, 2012 | 08:59 AM
Juice Box's Avatar
Nobody likes a bad shaft :(
Old Oct 26, 2012 | 09:01 AM
ttfhell's Avatar
My girl friend tells me the same thing. Ha
Think I should try a different brand or fight with the dealer!
Thanks WOL.
Old Oct 26, 2012 | 09:18 AM
drumnatural's Avatar
The stock Rzeppa and aftermarket double cardan require different pinion angles which is easily seen via the front pumpkin
Old Oct 26, 2012 | 09:30 AM
Jayrubicon's Avatar
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=382572"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=382573"/>
Isn't that the rear shaft
Old Oct 26, 2012 | 09:32 AM
I was always told its the same for both but the Internet can be a lier
Old Oct 26, 2012 | 09:41 AM
Jayrubicon's Avatar
According to what I've been reading on rzeppa joints they areade to handle big angles....
Rear propshaft. A double offset (Rzeppa) CV joint is shown in the photograph below of a rear propshaft connection to the rear axle of a 2010 Jeep Wrangler Rubicon. This type of joint can handle larger operating angles (10 degrees) as compared to U-joints (5 degrees).
http://www.vibratesoftware.com/html_..._CV_Joints.htm
Old Oct 26, 2012 | 10:02 AM
maine07jk's Avatar
Maybe it's just me, but it looks like from the pics, you have the fresh break and a crack that has some rust in it that may have been starting for some time.
Old Oct 26, 2012 | 10:16 AM
ttfhell's Avatar
I just zoomed in and saw that. I was in a hurry to get to work and just snapped the pics without taking a good look. Wonder if I could've dropped on a rock and cracked it and just finally broke. Hmmm
