Drive Shaft Snapped on Freeway
Old Oct 26, 2012 | 10:33 AM
  #21
Incognito's Avatar
Originally Posted by maine07jk
Maybe it's just me, but it looks like from the pics, you have the fresh break and a crack that has some rust in it that may have been starting for some time.
You have a good eye. That's definitely an old fracture; and a big one at that.
Old Oct 26, 2012 | 11:17 AM
  #22
bbrown626's Avatar
Originally Posted by drumnatural
The stock Rzeppa and aftermarket double cardan require different pinion angles which is easily seen via the front pumpkin
Attachment 382572
Attachment 382573
Neither of those depict a stock shaft. A stock shaft uses CV joints, not U-joints.
Old Oct 26, 2012 | 11:50 AM
  #23
nicker22's Avatar
I agree with what was said about the shaft having damage. You can see part of the break is fresh grey metal and some of it is rusted. Strange that would haven't have felt any vibrations prior to this. Just lucky nothing else got damaged.
Old Oct 26, 2012 | 12:08 PM
  #24
hypeiv's Avatar
unless he was driving in 4wd on the highway (which is obvioulsy a bad idea) this has to be prior damage from the trail that shook free on the highway
Old Oct 26, 2012 | 12:12 PM
  #25
hypeiv's Avatar
Prob would only feel vibrations in 4wd... if damage was on a slow trail and you shifted back to 2wd you wouldn't notice untill it finally gave out.
Old Oct 26, 2012 | 12:57 PM
  #26
1995nscajeep's Avatar
Just curious how big of lift
Old Oct 26, 2012 | 01:10 PM
  #27
ttfhell's Avatar
No 4wd on the freeway
4" lift with 37's.
Old Oct 26, 2012 | 04:31 PM
  #28
ttfhell's Avatar
4" lift with 37's.
Just got home and can't find the printout from the alignment. Going to see what the dealer says. I figure with the rust I must have smashed it, causing a crack and eventually it weakened until it blew.
Old Oct 26, 2012 | 06:38 PM
  #29
hypeiv's Avatar
Just go back to evo and get a better DS... sucks it will set you back $400-500 but you will be better off in the long run
Old Oct 26, 2012 | 08:38 PM
  #30
ttfhell's Avatar
Called them already They recommended a JE Reel 1350. I was thinking of doing it myself since I took the broken piece off the flange tonight. But since it blew up I'm worried about any transfer case damage or gear damage.
They only charge $110 for the labor which seems more than fair and is probably worth the piece of mind.
Thanks
