Engine light after evap relocation
Old Sep 29, 2008 | 10:10 PM
x No Compromise Offroad x's Avatar
Originally Posted by dyolfknip
When you relocated did you properly re-seat the gasket on the evap canister? The green one about 2" in diameter inside of the twist off piece (sorry dont know the tech terms). If that isnt seated right you will throw a code, had it happen to a friend of mine. Seat the gasket on the canister side and re attach the twist off piece.
I just did mine last week and didnt unhook the battery (wasnt in Woods instructions) and have not had a problem since.
what he said, but also rub a little oil on the ring to assist the seal
Old Sep 30, 2008 | 01:22 AM
dyolfknip's Avatar
I didnt say it cause it sounded so DIRTY
Old Sep 30, 2008 | 03:59 AM
seer1's Avatar
Also make sure you have it turned right side up. It'll give you a bunch of stupid codes and lights if it's upside down.
Old Sep 30, 2008 | 11:22 AM
so true....
Old Sep 30, 2008 | 03:37 PM
Strong Bad's Avatar
I appreciate all the feedback. I will give it a try and report back.
Old Sep 30, 2008 | 04:14 PM
old3's Avatar
I had similar and finally added 8 hose clamps to my extensions, one hose was loose after trying to push it over a lip on the can connector and was leaking. All good now, the computer will reset after awhile if the leak is corrected. I got the gascap readout & major and minor leak codes BTW.
Old Oct 1, 2008 | 07:26 AM
WitchKing's Avatar
same thing happened to me. I bought some hose clamps and placed them on all the connections....no more light
Old Oct 1, 2008 | 06:24 PM
jkboz's Avatar
Originally Posted by wrnglrguy
Can you post a pic of this line to get an idea of exactly which one you mean?
hope this pic comes through.
