ESP on or on
Old Apr 14, 2008 | 04:25 AM
aussie's Avatar
Default ESP on or on
hey I was going down a firetrail on the weekend I thought I would switch esp off so I could have a bit of fun. But when I got into it the esp was still engaged, or at least kept on working I got wheel spin in a straight line but not round a corner. any thoughts
Old Apr 14, 2008 | 05:18 AM
WV99XJ's Avatar
Id like to disable mine, anyone know how?
Old Apr 14, 2008 | 05:45 AM
TekWarren's Avatar
Do a search there is a write up on installing a switch that fully kills ESP
Old Apr 14, 2008 | 05:53 AM
cjsdad's Avatar
You can disable it completely for that session by pressing the esp button for 7 seconds. After you cycle the engine, it will go back to normal. When I'm off road, I just press the esp button for a second and it partially disables it. This still allows for some fun ie. doughnuts and such.
Old Apr 14, 2008 | 05:55 AM
MJS_Jeep_888's Avatar
First, RTFM.
Second, you can't turn ESP off fully in 2WD without modifying your Jeep... in 4HI, you can partially OR fully disable ESP:
To partially disable ESP in 4HI, press the ESP OFF button... this'll put the ESP into a more lax mode.
To fully disable ESP in 4HI, press and hold the ESP OFF button for 5 seconds; you'll hear a chime and your odometer will say "ESP OFF" if you're successful.
In 4LO, ESP is automatically disabled for you.
Happy Jeeping!
Old Apr 14, 2008 | 07:21 AM
WV99XJ's Avatar
[QUOTE=MJS_Jeep_888;437172]
[QUOTE]
This is what I want to do.
Old Apr 14, 2008 | 09:25 AM
hyatt147's Avatar
just out of pure curiosity, Why do u want to do this?
Old Apr 14, 2008 | 10:37 AM
Jordo89's Avatar
well for one so i can drive my own fawking jeep on an off ramp...
Old Apr 14, 2008 | 11:11 AM
Flatland Crawlin''s Avatar
Default 2 solutions
Aussie, et al,
I feel (well, felt ) you're pain. Here's a link to the thread dealing with installing the toggle switch:https://www.jk-forum.com/forums/show...ontra+code+esp
For anyone out there with an '08, you can follow the procedure below, found in the owner's manual. It takes a few tries to make it work, I've found, but it completely disables the ESP without having to lose your anti-lock brakes or risk the dealer bitching about warranty violations.
" The following procedure will disable ( or re-enable) ESP functionality in the vehicle.
1. Shift the transfer case into the 4H range position.
2. Turn the steering wheel until it is centered and the wheels are pointed straight ahead.
3. Cycle the ignition key OFF to ON.
4. Wait approximately five seconds for the system bulb check.
5. Turn and hold the steering wheel one-half turn to the right (clockwise).
6. Press and hold the ESP OFF button for seven seconds.
7. Turn the steering wheel back to center, and turn and hold an additional one-half turn left (counterclockwise).
8. Press and hold the ESP OFF button for seven seconds.
9. Turn the steering wheel back to center.
10. Press and hold the ESP OFF button for seven seconds.
11. Cycle the ignition key to OFF.
After performing the ESP disable procedure correctly, "ESP OFF" will be displayed in the odometer for approximately 12 seconds each time the ignition is move to ON. Repeating the ESP disable procedure will re-enable normal ESP operation."
Best of luck.
--C
Old Apr 14, 2008 | 05:40 PM
Northernmedic's Avatar
anyone know if this sequence will work for an 07?
