Hood vents
Old 05-29-2016, 08:36 PM
shabbernigdo's Avatar
Originally Posted by 15JKU84
whats the point of the vents? Are you guys seeing overheating?
They help to keep the engine bay cooler which in turn helps to extend the life of the componets / plastics and such under the hood.
Old 05-29-2016, 08:56 PM
ronjenx's Avatar
If it's lower under-hood temps you are after, check this thread: https://www.jk-forum.com/forums/modi...trofit-235132/
Old 05-30-2016, 03:32 AM
ReconJeep's Avatar
I did this mod in my 09 JK. Anyone know if this can also be done in the newer 3.6? I looked in the engine compartment and couldn't find the threaded portion on the water pump.
"Ex Umbris Venimus"
Old 05-30-2016, 05:48 AM
GunDude's Avatar
ronjenx, thanks for the link and write up. I going mechanical fan route.
Old 05-30-2016, 04:21 PM
15JKU84's Avatar
Ive never noticed my JK running warm when crawling or creeping around a trail. So it sounds like this must be a common issue with the JK's? Or is it because the hardrock's come with hood louvers? I guess what Im asking is, is it actually an issue, or a precaution? TIA
Old 05-30-2016, 05:51 PM
kmrtnsn's Avatar
It's amazing how much heat comes off of your hood idling in the desert. I vented my hood; cheap insurance.
Old 05-31-2016, 07:10 PM
jchappies's Avatar
Old 06-07-2016, 12:20 AM
GunDude's Avatar
Originally Posted by MontanaRaptor
I put some West Marine hood vents on my hood. They turned out really nice and I've never had any issue with moisture getting in there. They were cheap too! https://www.jk-forum.com/forums/modi...-vents-272989/
Thanks to MontanaRaptor for the link to the $20 hood louvers from West Marine!! I added a piece of aluminum over passenger side fuses, just because had it laying around.
ID:	649040   Click image for larger version
ID:	649041   Click image for larger version
ID:	649042   Click image for larger version
ID:	649043   Click image for larger version
Old 06-10-2016, 10:36 PM
MontanaRaptor's Avatar
Wow!! Those are sharp looking vents! Glad I could help out. Yours look almost in the exact position of mine, great job!
Quick Reply: Hood vents
