Hypertech/ AccuPro working or not
Old Feb 15, 2008 | 10:38 AM
  #31
Phil Howell's Avatar
Originally Posted by Eracer76
Im just wondering if changing the gear setting is causing a negative effect on programing the speedo?
Changing gears in the JK has NO effect on the speedo, it uses wheel sensors to determine the speed of the Jeep, not a trans sensor.
So you should not have to change the gear setting in the programer, only the tire size.
You're right, the JK only uses wheel sensors for the speedometer and odometer. Programming the gear ratio change optimizes transmission shift points. I don't think that programming a gear change is having a negative effect on the speedometer programming. At least, it didn't on mine.
Old Feb 15, 2008 | 02:27 PM
  #32
doctorrich's Avatar
Originally Posted by bOLsAK=3
Damn... I feel bad for Darnell.
Me, too. He's doing a GREAT job at customer service. Going above and beyond.
Old Feb 15, 2008 | 02:52 PM
  #33
Piginajeep's Avatar
If your having issues please post them here
https://www.jk-forum.com/forums/sponsoring-manufacturers-vendors-check-out-cyber-monday-specials-24/trouble-w-hypertech-post-here-28892/
I'm closing this thread so he doesnt not have to keep bouncing back and forth.
thanks
