Lift coils with winch
I currently have a 3.5” procomp lift but looking to upgrade for a better ride. My coil choices have been narrowed down to RK and Evo. I want to keep the same height but will be adding a new heavier bumper and a winch. I want to eliminate sag for an even rake.
My question is would it be better to get 4” coils in front/3” coils in the rear or the same lift coils but a spacer in the front? Any suggestions would help. Thanks
Former Vendor
Copied and pasted from the other place you asked this.
Typically we use spacers to account for a Jeep that isn't balanced front to rear. Adding a large bumper and winch without similar rear modifications, tends to cause a lean forward, we would typically recommend a spacer before recommending a taller spring. That way if you eventually add a matching rear bumper/tire carrier/armor etc, you can remove the spacer and the jeep will be level.
Adam C.
Adam C.
A compressed spring with a spacer is still a compressed spring. Replacing with springs that will accommodate the increase in weight on the nose is the correct solution. Look at OME springs. OME makes springs just for this problem.
Former Vendor
Adam C
I would agree IF he is done adding parts to his Jeep. If OP were to add a rear bumper and tire carrier, his jeep would level out and the spacer would be removed which is free. If he opted for a longer spring the first time, he'd now have to deal with springs again.
Adam C
Adam C
Former Vendor
False, having the practicality of adjustment is not a form over function argument, it is a practicality argument. As I had previously stated, if he were done modifying the vehicle, we would recommend he go a different way but as he is not, we would wait until all weight is added first. We are not a company that is just in it for the look, we are a company that loves wheeling hard and we always will be.
Adam C
Adam C
