locker locked?
Old Aug 29, 2008 | 03:25 PM
  #21
rubiconjack's Avatar
Originally Posted by 0311sgt
Pardon my ignorance but i was under the assumption that all Jeep Wranglers came with Dana 44 rear now? I am asking this because you said you bought front and rear dana 44's. at least your price quote implies this since a dana 44 is only $1500 and you paid over $3500.
for both front and rear, wiring harness and switch and overweight shipping (overnighted) and installation was at 3500 - 3600. Not sure the exact amount.
My JK .. I have a unlimited X .. now a cross breed of X and Rubi' ...
It came stock with open differentials, 3.73s, and a D30 Front and D35 rear.
It seemed like a good deal, compared to the 5500 dollar engine we had to replace a week earlier ... haha ... the axles had to get fixed the day we got it back from the dealership! It didn't get driven from the time I 'blew' my engine ... to pick up .. and driven home, thats when we found out that my axles needed upgraded too... damn!
Old Aug 29, 2008 | 03:35 PM
  #22
Default can the dealer change it?
Can the dealer make it so the LOCK engaged light will be illuminated in an X with Rubicon axles?
My husband was wondering this ... its worth a shot ain't it?
Old Aug 29, 2008 | 05:52 PM
  #23
wrnglrguy's Avatar
I would imagine they could if you bought the $600 wiring harness that was mentioned earlier. All the lights are already there on the instrument panel. Just need the correct harness to hook it up. I put factory fog lights on my last Jeep. It didn't come with them when I bought it. Since they were from the factory, I bought the entire kit, which included the new blinker switch with the on/off for the fogs, and the wiring that turned on the "fog light indicator" light on in the instrument panel. I would think that the same would apply if you bought the factory lockers AND the full wiring harness...the entire kit.
Old Aug 29, 2008 | 07:00 PM
  #24
Piginajeep's Avatar
they got your lockers to work with the harness and stock rubicon switch?
  #25
Piginajeep's Avatar
Originally Posted by RedneckJeep
My question would have to be why in the hell did the butchers put the switches under the steering wheel when there is a factory switch panel in front of the shifter?
You can easily tell if the lockers are locked. Get in some sand or dirt in 4x4 lo and stand on the gas while somebody is outside the Jeep. If they tell you all four spin, they are locked, if not, they ain't.
hell, just lock the front and try to turn...
Old Aug 29, 2008 | 07:01 PM
  #26
Piginajeep's Avatar
as far as I know, no ones has got the harness and switch to work like factory on the x model.
Old Aug 29, 2008 | 07:25 PM
  #27
RedneckJeep's Avatar
That's actually quite easy. Just yank up the parking brake and cut the wheel. It'll turn.
Old Aug 30, 2008 | 02:18 AM
  #28
guinness's Avatar
This thread started a long time ago.
I bought marionnc's jeep from him in the spring.
He put the rubicon 44's in the front and rear and had the lockers wired to simple toggle switches rather than spend alot of extra for the jeep wiring harness.
By doing this the rear locker can be engaged in 2wd, 4hi and 4lo and the front will engage in 4hi or lo.
And yes the lockers both engage and like you all said you know when they are locked esp. the front.
Old Aug 30, 2008 | 02:25 AM
  #29
pearl-drum-man's Avatar
They do now, though the Rubicon rear D44 is 32 spline, where as the X version is 30 spline. I don't know what his JK is, but if a two-door from '07 he could have been one of the few unlucky people to get the D35 rear.
Old Aug 30, 2008 | 03:11 AM
  #30
jeeperjkj's Avatar
Yeah, you're wrong. ARB makes one. The only difference between the JK rear 44 locker and the rest is the ring gear bolt holes. You can use any kinda locker or limited slip if you drill the ring gear bolt holes out to the JK size. Detroit Locker, here I come.
I should've said that I didn't think there were any manufactured for the JK. I realize you can modify some to work, but I still don't think that any are manufactured for the JK.
