Longarm kits compared/contrasted
I had a triangulated top 3 link on the desert truck and it came loose. It was at much higher speeds than what a typical Jeep would be at,but when it did,it did some massive damage. I keep thinking about that every time I see a 3 link JK. Burned into my mind..lol
Man this stuff gets really hard to compare...
I love Dirtman's info, I've read the stickie a couple of times, but I still have a hard time comparing my BDS lift with these other ones, I just want something that's really good off-road, not too easily broken, and still o.k. on the road.
Last year I did manage to bend a factory left front lca and a factory right rear lca, but nothing broke and it just showed up when a did the Dynatrac swap.
matthew
matthew
Someone out my way had the rock Krawler 3rd link break off while wheeling. One could argue it was the weld job, but in the end, it did break.
The latest JKX video shows the effects of a broken 3 link (twice), they had to tow him off Cadillac Hill....
Synergy and EVO instructions are to partially cut the rear body mount and install the bracket to what's left. Does that provide enough length?
Dual triangulated 4 link rear -- found pics and looks sweet. However, I wasn't able to find many kits, and on Genright's site, it recommends the 4 link for those who spend 80% offroad only, and that's not me.
Planman -- Are you sure TNT makes a 3 link upgrade kit? It's not on their website....
roscoj -- the high clearance mounts only work with the EVO Lever unfortunately, they were on my list until I learned that.
His break was due to a poorly designed bridge over the diff and we told him it was not good enough but he chose to run like that anyway.
A double triangulated 4 link like genrights works just fine for a daily driver, not sure why they say off road. Maybe has something to do with the fuel cell.
The biggest issue that I see with the 3 link rear other then strength is to get the geometry right you loose up travel due to a really tall axle mount.
The evo high clearance bracket kit is designed to work with their cantilever system. But it can be modified by welding on shock mounts wether using coilovers or not. I was going to do this mainly for clearance on the frame side mounts.
A picture of what I mean.
Those are 2 different items in the pictures? Frame side mounts? Maybe Im misunderstanding.
