Minimum lift
Old Feb 12, 2013 | 05:21 PM
4x4Play's Avatar
Default Minimum lift
Would using body spacers (2.5" front & 1.75" rear) and switching to flat fender flares create enough clearance to put 35's on my Jeep? I want to put them on my 17" Rubi wheels.
Old Feb 12, 2013 | 05:26 PM
afpilot82's Avatar
JK-Forum Ambassador
If you're going to use a body lift, it needs to be the same all around. Are you thinking about coil spacers?
Old Feb 12, 2013 | 05:29 PM
4x4Play's Avatar
Sorry. Yes, coil spacers. I think the difference is intended to be leveling.
Rubicon Express RE1324 2.5" Front Coil Spacer for Jeep JK : Amazon.com : Automotive
Rubicon Express RE1326 1.75" Rear Coil Spacer for Jeep JK : Amazon.com : Automotive
Old Feb 12, 2013 | 05:33 PM
afpilot82's Avatar
JK-Forum Ambassador
I get that. Those are coil spacers, not body spacers. Yes, you'll be able to fit 35s with that set up.
Old Feb 12, 2013 | 05:36 PM
4x4Play's Avatar
Thanks. Would there be any concern about rubbing or any other issues to worry about?
Old Feb 12, 2013 | 05:40 PM
Jeepstin12's Avatar
I did 35" nitto trails on my rubi and had little rub on road, off camber parking lot entry, etc. I did a 3" full traction lift and have plenty of clearance. I did swap out my wheels to the method fat 5. 2.5" with stock wheels? More than likely rub off road. A friend of mine had a 4 dr Sahara, 2.5" with 35's and stock wheels. It was ok on road. He never took it off road. He said he would still get some tire scrub on off ramps with a few friends in it.
Old Feb 12, 2013 | 05:42 PM
4x4Play's Avatar
Was this with stock fender flares or flat flares? I am looking at the Bushwacker flat flares. They look like they will open it up quite a bit.
Old Feb 12, 2013 | 05:46 PM
SBEII's Avatar
35" tires on a 1.5" leveling kit.
ID:	421649   Click image for larger version
ID:	421650   Click image for larger version
Old Feb 12, 2013 | 05:49 PM
4x4Play's Avatar
That looks great! Exactly what I'm looking for.
Old Feb 13, 2013 | 11:39 AM
Lusky's Avatar
What sliders are these?
