Mount for 4lb or 5lb fire extinguisher
Old 03-09-2015, 09:15 AM
MAG00's Avatar
Default Mount for 4lb or 5lb fire extinguisher
I know there have been quite a few threads about fire extinguishers and mounts. However, most of them discuss mounting the smaller 1 or 2.5 lbs units. My work is requiring that all project managers that use their vehicles to travel to job sites to carry 4 or 5 lb ABC fire extinguishers. So I am looking for a good mount and mounting location for a 4 or 5 lb fire extinguisher.
Any ideas or recommendations?
Would something like the power tank bracket work? Other similar products?
Thanks.
Old 03-09-2015, 09:19 AM
TURTLECON's Avatar
Smittybilt or powertank air tank mounts should work for your needs. There's also a variety of rollbar mounting options out there. A search should find you a lot of choices. Check out fourtrek as well.
Old 03-09-2015, 10:49 AM
Mike H.'s Avatar
me too, 5lb, have not figured anything out yet.
please report back with what you find.
Old 03-09-2015, 11:17 AM
RAMbone's Avatar
I don't recall the size but I put this at the left rear of the cargo area. You could probably fit a larger model back there as well.
Old 03-09-2015, 11:45 AM
MAG00's Avatar
Can you give some details as to how you have that mounted? Looks like you may have used a bracket that came with it, but not sure how you have attached it. Thanks.
Old 03-09-2015, 12:07 PM
RAMbone's Avatar
I just secured it with some sheet metal screws, its been there 3 yrs, no problems.
Old 03-09-2015, 12:43 PM
KenB1010's Avatar
take a look at the Drake Off Road fire extinguisher mount.
Old 03-09-2015, 01:24 PM
YD215's Avatar
http://www.kartek.com/Product/1757/H...her-Mount.aspx
Old 03-09-2015, 01:28 PM
YD215's Avatar
This is the tread I started with this same question. https://www.jk-forum.com/forums/modi...lution-315067/
Old 03-09-2015, 01:33 PM
TreyJK's Avatar
Check out quick fist mounts, I use them for my CO2 tank and have no complaints
Quick Reply: Mount for 4lb or 5lb fire extinguisher
