My HEMI Conversion!!
or the wife will be eventually kill me
I was thinking the same thing but I've read others on here that kept their 5.13 gears and they are doing fine. I mean your MPGs may drop alittle but not by much. I will be also adding some Coast 1350 driveshafts to handle the extra TQ that this bad puppy will be putting out. Eventually I'll be upgrading my front and rear axles to Dana 60 by next summer. This addiction of mines is becoming EXPENSIVE...lol!!! I've got to spread out my high
.Interested to hear about gearing results. I'm debating going from 4:10s to 5:13s as well. Hemi gives plenty of power to overcome gearing, but always interested in optomizing performance. Keep us posted!
Originally Posted by Baddintentions4u
Well it's confirmed, the motor and tranny is out of a 2011 Jeep Commander according to Chryslar. I can now order my conversion kit, so far I have to order the conversion kit (AEV $5,400.00), the tranny adapter ($215.00), Seal for the adapter ($20.00), New Valve body for the tranny conversion ($500.00), Valve cover ($120.00) and Coil pack ($25.00). For a total of $6,280.00 plus or minus other parts like belt and fluids and stuff. Oh well guess I'll start order and get ready for the swap of a lifetime
.Well it's confirmed, the motor and tranny is out of a 2011 Jeep Commander according to Chryslar. I can now order my conversion kit, so far I have to order the conversion kit (AEV $5,400.00), the tranny adapter ($215.00), Seal for the adapter ($20.00), New Valve body for the tranny conversion ($500.00), Valve cover ($120.00) and Coil pack ($25.00). For a total of $6,280.00 plus or minus other parts like belt and fluids and stuff. Oh well guess I'll start order and get ready for the swap of a lifetime
The dodge Ram comes with 3:50 or 3:73 gears but of course the tires are 31's or 32's. The 5.7 produces more torque at 1200 rpm than the 3.8 does at peak. That is the reason I was thinking 4:10 for 35's.
I think you're on to something. My avalanche had 4:10's. If I didn't get the pulling package it would of had the 3:73's.
I think the 5.13s will work out fine, especially with rockcrawling. My MPGs may take alittle dive but some times in life there are trade offs. I plan on going to Dana 60s next summer so I don't want to invest in the axles anymore than I already have.
I am creeping up on 30k miles with the 6.1, and still run the stock drive shafts. However, I am not lifted, run stock gearing and tires, and do not rock crawl. Most stuff I run does not even require 4-lo.
I do hammer it on the (back) roads fairly often, and am impressed with just how tough the stock drive train has been. I really did not expect the stock shafts/transfer case to last this long.
I imagine if you increase the pinion angle with a lift, add big tires, and start climbing over stuff replacing the driveshafts would be a good idea even with the 3.8, much less a hemi.
If I ever go 35" tires I think I would prefer 5:13's with an auto.
