My Jeep keeps going left !!!!
If I'm not mistaken, your axle usually shifts toward driver side (if not may have in your case) after installing a lift of 2.5" and up. Add your SS mounted the way it is (toward driver side) and add in the fact that a piston will always try to decompress, this very well may be your issue and a $0 fix...
I have a TF 4" full 8 arm kit installed here at home, running 37" Trail Grapplers and mine pulls left also. I have had it into Teraflex twice to have it aligned and everything is up to snuff, they think it has got to be a radial pull. And no I didn't swap out my SS, it's still stock. Thoughts? From what I have read, it seems everyone with a radial pull seems to pull right so why would it be any different for me? Not trying to steal the thread, but just putting input in from somebody else that pulls to the left.
Let me know if you have fixed the issue if not come to fredericksburg and we will figure it out i have a place with a lift and all the tools not to mention i have the exact aev lift sitting in my garage waiting for install.... im still waiting on my atx slabs and toyo m/t .
Hey PD2PLA what's the address? Might contact u and have a look, I don't if that is stupid but I turned the SS the other way round but still goes left, will try and change to the original SS ....
Try it with none or the stock one. Since the solid mounting point is the axle housing itself, the gas charged SS is going to puch the tierod no matter which way its mounted.
Thats a good point ill remember that when i do my lift.... UAE455 give me a call at 540-295-1724 if you need some help the shop is packed but we can move stuff around and do what we have to do.... Also have you been on the aev forum and discussed this issue with them?
