paint
Old Apr 16, 2009 | 07:09 AM
JMP8562's Avatar
this is your best bet .. go to any auto part store and buy some ceramic exhaust/muffler/header paint (rattle can) sand the rust off wipe it clean then use either deglosser or the cheap way achohol put 2 coats on with in 20 min first coat will dry quick, follow the directions for tempering the paint use the oven to heat treat it the thing is you only have a few choices of colors after they cure and before you install them throw a coat of wax on... the good thing about the deglosser is it will help the paint bond with each other let us know how it turns out "pictures are good"
Old Apr 16, 2009 | 08:50 AM
robin's Avatar
Originally Posted by JeffD
Just get a rattle can of Rustoleum. Clean them up good with some mineral spirits, scratch them with sand paper (320 or 400) and spray them. It will look perfectly fine and last a long time. Plus it's cheap enough you can always do touch up later by just squirting and spots that start to look bad.
this is what I would do, unless I was changing the color.
Old Apr 16, 2009 | 09:13 AM
MJS_Jeep_888's Avatar
I would highly recommend Krylon or Rustoleum in a rattle can... sand any rust off first, apply some flat primer, spray a few even coats with the color of your choice, and then (optionally) hit them with a few coats of triple gloss.
I sprayed my vent rings about 2 years ago, and the triple gloss has been awesome - it dries really hard, and is doing a great job resisting cracking/scratching, etc.
Old Apr 16, 2009 | 09:48 AM
tkob1060's Avatar
From: Hangin in the sunshine state....staging forum..
scuff them up with a 3M scuff pad, give the paint something to stick to
Old Apr 16, 2009 | 09:14 PM
nangulator's Avatar
Originally Posted by tboginski
i'm gonna go blue or green...maybe silver since my whole jeep is black and silver..not sure yet, a fellow forum member is trying to get me to paint them pink
If you paint them pink, I want to see a pic to show my daughters
Old Apr 16, 2009 | 09:20 PM
hunterbug's Avatar
Bed liner spray ? Black is always cool.
