Papa needs new front driveshaft, What should i consider?
Old Dec 10, 2012 | 02:22 PM
Incognito's Avatar
Ordered a Coast rear 1310 from NR4X4 and it came with Spicer joints.
Old Dec 10, 2012 | 02:38 PM
ronin2120's Avatar
Vet Army
My Coast drive shafts from Northridge came with Spicer as well.
Old Dec 10, 2012 | 02:40 PM
Maertz's Avatar
Coast 1310l spicers from nortridge 4x4
Old Dec 10, 2012 | 02:41 PM
Freewill's Avatar
Somebody correct me if I'm wrong, but I thought only the stock drive shaft has a boot.
If yours was stock, then I don't think you had a CV joint. Again, I could be mistaken.
Anyway, if you go from a stock-type shaft to a CV shaft, the pinion angle at the front axle should be reduced to just a degree or two. Don't set the pinion angle to zero degrees however because the needle bearings wont turn enough to distribute the grease.
Old Dec 10, 2012 | 04:21 PM
bbrown626's Avatar
Stock shafts use CV joints (Rzeppa?). The common atermarket CV joints are double Cardan.
Old Dec 10, 2012 | 04:37 PM
hneiper's Avatar
That was my understanding too.
Old Dec 10, 2012 | 04:42 PM
Freewill's Avatar
I wasn't sure when I posted earlier, but I just visited half-dozen "answer" sites to check this out. They all say the same thing: CV is another name for Double Cardan.
AFAIK the stock shaft uses a standard U-joint at both ends. If the stock shaft used a CV/Double-Cardan the pinion shaft would not be parallel with the ground from the factory.
Old Dec 10, 2012 | 04:46 PM
hneiper's Avatar
All nice drive shafts, but hypothetically speaking if one were to break one on the trail how common are the parts each of them use if I needed to replace. In other words, aside from catastrophic failure that requires a new entire shaft what other things should I consider. The obvious one are the u-joints. Anything else from a trail recovery situation?
I've made a lot of crappy decisions on what I buy for my jeep so now I just want to be sure I've done my homework.
Old Dec 10, 2012 | 04:53 PM
Northridge4x4's Avatar
Sponsoring Vendor
Even from coast You have to specify Spicer.I did not know that.
Every coast driveshaft we sell comes with spicer joints.
David
Old Dec 10, 2012 | 04:57 PM
hneiper's Avatar
David
That's good to know because ill be ordering from you when I do.
