Rear Spring install question
Old Mar 7, 2009 | 03:31 PM
  #21
wayoflife's Avatar
JK-Forum Founder
Originally Posted by JRod
Well, respectfully sir, on my 08 Unlimited, as of yesterday, there is an index on the LOWER REAR spring perch. Maybe they are not all like this, but on mine there is. I just went outside to snap a pic, but with the spring in and the weight of the vehicle on it, I can't get a clear enough pic to post up.
if that is truly the case, that would be a first for me and i would imagine this may pose a problem once you have to set your pinion angle. here are shots that i just took of my 07 lower spring perches.....
as you can see, it is completely smooth around the nub and there is no index to be found. does yours really not look like this?
also, here is a shot of the rubber isolator. as you can see, it is completely uniform and there is no index to be found.
ID:	20383   Click image for larger version
ID:	20384   Click image for larger version
Old Mar 7, 2009 | 03:35 PM
  #22
wayoflife's Avatar
JK-Forum Founder
here is a shot of the new JKS adjustable rear spring perches. as you can see, they do not have any indexing either....
smooth, round and uniform all the way around as it should be.
Old Mar 7, 2009 | 07:53 PM
  #23
cju777's Avatar
So with the caster now 1.59 on the left and 1.78 on the right shoukd I just get front lower control arms, or adjustable ball joints?
I am going ot Moab for a light off-road trip with some other JK's in my unit next week, should it be alright to do some light to medium trails or do I need to get that fixed ASAP.
Thanks
Old Mar 7, 2009 | 07:57 PM
  #24
wayoflife's Avatar
JK-Forum Founder
Thanks
i don't get it. how could you possibly only have a little more than 1° of caster? if that is really true, your jeep should handle like crap and on the verge of DW. are you sure that's right? if it is, you need adjustable lower control arms. adjustable ball joints would never be able to give you enough caster.
Old Mar 7, 2009 | 08:02 PM
  #25
cju777's Avatar
That's what the place told me, according to their printout, they even recommened to get the ball joints.
I am going to go out and buy one of those angle measurement tools, haven't heard of that much loss in caster on this small of a lift.
Old Mar 7, 2009 | 08:08 PM
  #26
wayoflife's Avatar
JK-Forum Founder
assuming nothing else was changed other than the addition of taller coils, you should still be at about 4° even at 3" of lift or more. those numbers do not sound right to me at all. likewise, if these numbers were really correct, you would need to add about 4° to get thing to a point that is nice and i don't know of any offset ball joints that can give you that much and even if they could, it really is the wrong way to go about it. honestly, wouldn't take your jeep back to these guys as they don't seem to know what the hell they are talking about.
Old Mar 7, 2009 | 08:18 PM
  #27
cju777's Avatar
WoL - Thanks, good advice. I'll probably just start doing it all myself. I bought the Jeep to learn it all anyway!
Thanks all for help on the thread, we'll see how she runs!
Old Mar 7, 2009 | 08:27 PM
  #28
Preciousmetal's Avatar
I just did my 2007 unlimited X today my lower spring perch is just like Wayoflife's, but my upper rubber isolator is different I don't have the long rubber bumper in the middle, so what I'm going to say here Jeep must have use some different components on some models verses others. When I put mine in, I just looked at the stock springs and put them in the same postion when I installed the new springs. Mine are heavy duties too.
Old Mar 7, 2009 | 08:30 PM
  #29
wayoflife's Avatar
JK-Forum Founder
i'm sorry but the rubber thing in the middle is a teraflex spring retainer - i just didn't bother to take it off when i took the photo.
